Unleaded fuel and the Fiesta Turbo
Old Mar 25, 2006 | 01:19 PM
Oranoco's Avatar
Oranoco
Default Unleaded fuel and the Fiesta Turbo
I was always of the opinion that it should always be run on Super Plus but I'v erecently been told as standard they are fine on the 95 RON stuff. I'm not convinced but wanted to hear other peoples opinions on this
Old Mar 25, 2006 | 01:22 PM
rauri's Avatar
rauri
up in smoke........
i ran mine on normal for about a year with no probs (just coz its hard to get super/optimax) where i live
previous owner did the same with no probs either
Old Mar 25, 2006 | 01:23 PM
MadMac's Avatar
MadMac
Should be find on either, just more likely to get det on 95 than 97 and get a little less power as far as I know. I'm sure the FRST EFI management has a knock sensor so it would automatically compensate if you run a lower RON fuel.
Why the cost of premium getting to you steve
Old Mar 25, 2006 | 01:28 PM
Oranoco's Avatar
Oranoco
No Mac was on FT and somebody said they were fine on normal 95 stuff. The Escort only get's the finest Optimax and the Fiesta is on new zero emmision air pistons.
Old Mar 25, 2006 | 01:30 PM
MadMac's Avatar
MadMac
lol, well a FRST should be able to compensate. With your RS I would throttle you if you ever put anything else in it
Rippers's Avatar
Rippers
Monte Geek
Mine was only ever run on Super
Old Mar 25, 2006 | 01:31 PM
Jim Galbally's Avatar
Jim Galbally
im pretty sure the std map is good for 95
Old Mar 25, 2006 | 01:38 PM
Billabong's Avatar
Billabong
FRST (std) can run 95RON UL - it did from the factory. I've always ran SUL or Optimax in my RS's though, the engine seems to prefer it (even when std).
Old Mar 25, 2006 | 02:46 PM
Mint FRST's Avatar
Mint FRST
Standard - wont harm it, although I would expect an enthusiastic owner to run it on SUL.
Chipped/raised boost - definately
My 1st FRST used to pink on UL. However it did put out 156Bhp on only 9psi which was excellent for a standard unchipped car.Perhaps it was telling me something
Old Mar 25, 2006 | 02:51 PM
SassyRS's Avatar
SassyRS
Little Miss...
Optimax
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Bailes1992
Aug 16, 2015 07:14 PM
turbobill
Aug 1, 2015 08:55 PM
