Oh GOD...changing plugs on a Skyline.
Old Jul 28, 2004 | 03:30 PM
Ima-Racing500's Avatar
Ima-Racing500
Default Oh GOD...changing plugs on a Skyline.
As many know i am a goon..ROFL.......but i feel a knowledgable goon re Cosworths..as i have learnt it all myself with no former mechanical experience...so saying what i am about too does not make ME feel stupid as this GTR is a new learning zone
Ok i decieded to have a look at what spark plugs it runs.....and fuck ,where are they? Took the middle cover off..like taking a Cossie rocker cover off except the cam cover breather pipes have to be disconnected and a module unplugged two ends..which aint that easy So i now see NO LEADS but grp a looking coils x 6 Thats as far as i got as these need taking off as i am assuming the plugs are underneath...Now i am having a stab in the dark by saying these are coil packs????
Can someone explain how this setup works compared to conventional?
THANKS.
Old Jul 28, 2004 | 03:43 PM
kris's Avatar
kris
probably a seperate coil pack on top of each plug used by quite a few manufactures nowadays VAG 1.8t engine has the same instead of one coil pack and ht leads.the seperate coil packs are usually held in by two screws/bolts just undo these lift off the coil an the plug will be underneath
cheers
kris
Old Jul 28, 2004 | 03:44 PM
Jim Galbally's Avatar
Jim Galbally
yes, individual coil per cyl.
yes the plugs are underneath
works exactly the same as a normal setup only there are 6 of em
Old Jul 28, 2004 | 03:49 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
You fookin spazzo IMA
Take the plug cover off, pull off the coils off the top of each plug, change the plugs, refit, 10min job.
Bet you been arguing with em down halfords as they didnt list fookin plugleads, dizzycap, and rotorarm
Old Jul 28, 2004 | 03:54 PM
AlexF's Avatar
AlexF
They are called "coil on plug"
so called coz its just that!
All BMW engines now use this as do alot of VW and nearly all jap stuff.
alex
Old Jul 28, 2004 | 04:01 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Only trouble with coil on plug malarky is heat killing them.
And also when you got mega power and need better coils aftermarket ones are either not up to much, ripoff, or both.
Easy way around this tho, like Keiths new setup...
Old Jul 28, 2004 | 04:33 PM
Ima-Racing500
Cheers...BUT how does the system work....and is it much better than the conventional route?
Old Jul 28, 2004 | 04:39 PM
AlexF's Avatar
AlexF
It works in the same way...
a coil generates a high voltage pluse and instead of transmitting that down an HT lead and into the plug you are directly delivering the high voltage directly to the plug.
Connections are always the weakest link in an electrical circuit, so reducing the number you have is always a good thing!
alex
Old Jul 28, 2004 | 04:56 PM
Ima-Racing500
Cheers Alex
Old Jul 28, 2004 | 05:35 PM
Mark_w's Avatar
Mark_w
and they are good plugs phil,that are not very old and best left alone if its running ok
Old Jul 28, 2004 | 05:44 PM
Ima-Racing500
Mark any idea of the part number??Need to see if they are the correct heat range for the 1 bar with HKS filters/exhaust its now running.
Old Jul 28, 2004 | 07:09 PM
Mark_w's Avatar
Mark_w
no idea phil,should be on the service reciept i gave you
mark
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
