Cars & Parts Wanted. Need a specific car or part? Ask in here!! Starting a topic requires you to have purchased a gold membership.
4x4 cossie loom needed everything apart from engine loom
Old Mar 14, 2006 | 04:19 PM
steve rs's Avatar
steve rs
Default 4x4 cossie loom needed everything apart from engine loom
4x4 cossie loom needed everything apart from engine loom. i need everything apart from the bit past the 3 multi plugs that go to the injectors etc. this is needed fairly quickly
thanks
Steve
Old Mar 14, 2006 | 06:57 PM
SPADGE's Avatar
SPADGE
So you want the bit that goes from ecu to the 3 connecting blocks under the boonnet?
If so then i have one
Old Mar 15, 2006 | 01:23 PM
steve rs's Avatar
steve rs
bttt whole loom needed
big_Rad
Sep 15, 2017 09:36 AM
EoinXR3
Sep 7, 2015 05:44 AM
kosienutter
31
Aug 22, 2015 09:55 AM
col93saphcos
Aug 7, 2015 03:21 PM
Old ford
Jul 31, 2015 06:50 AM
