cosworth 2wd issue
Old Feb 22, 2006 | 10:08 PM
danstocker123's Avatar
danstocker123
Default cosworth 2wd issue
My cossy keeps blowing a fuse which is to do with the fuel pump. Literally every mile it will blow. The fuse is where all the fuel pump slonoids etc are under the passenger dash. Please help
Old Feb 22, 2006 | 10:19 PM
rapidcossie's Avatar
rapidcossie
something prob to do with bad wiring or a bad earth??
have you checked for loose connections at the pump etc??
Old Feb 25, 2006 | 06:51 PM
wimble's Avatar
wimble
i had this problem on mine. I found it was the wires to the amel valve were ber and arking out it might not help but its worth a try
Oct 9, 2015 07:38 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Aug 14, 2015 07:29 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
Old ford
Jul 31, 2015 06:50 AM
