xr3i turbo question
Old Feb 22, 2006 | 06:59 PM
rs_escortturbo's Avatar
rs_escortturbo
Default xr3i turbo question
could anyone tell me how much psi i could run on a standard xr3i with just the basic rs t3 turbo and standard intercooler without doing too much damage,i dont expect massive boost but just to give it that bit extra.
Old Feb 22, 2006 | 08:23 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
YOU CANT JUST BOLT IT ON MATE
ANY BOOST AT ALL WILL MAKE YOU RUN LEAN AND LEAD TO DET
MORE BOOST THE LEANER U GET LEAN= MELT IN SECONDS
I WOULD SAY IF YOU DONE THIS PROB ABOUT 2-3 PSI
REMEMBER THERES ALOT MORE WORK TO DO LIKE OIL RETURN/FEED
BREATHERS ETC
HOPE THIS HELPS
Old Feb 22, 2006 | 08:41 PM
rs_escortturbo
i know all about the return pipe for the oil and the oil feed pipe,i have all the stuff to run the turbo,i was just wondering how much psi i could run on it,another question,besides the injection system and ecu's,is there much of a difference in the xr3 to the rs,does it not have the same fueling setup
Old Feb 22, 2006 | 08:53 PM
Avinitlarge's Avatar
Avinitlarge
Completly different fuel distributor, The Rs has 2 ecu's, The black ecu controls the fuel and the silver ecu controls the ignition, It uses a different dizzy too. I tried to run the std k jetronic with a turbo, It did work but it worked alot better with the ke jetronic
haz87's Avatar
haz87
xr3i is k-jetronic
Rs ke-jetronic
Old Feb 22, 2006 | 08:56 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
BOOSTING
Old Feb 22, 2006 | 11:16 PM
rs_escortturbo
Thanks for all the info guys,il give it a go anyways and see how it runs,im not looking for miracles but it would be nice just to have that extra bit of boost anyways....
Old Feb 23, 2006 | 11:19 AM
JesseT's Avatar
JesseT
If you're going to use the K-jetronic, you should use the control pressure regulator from a turbo version. At least old 900 turbo saabs use one that can be borrowed.
Old Feb 23, 2006 | 05:36 PM
rs_escortturbo
Thanks for the info jesseT,can you tell me where on the k-jetronic id find the control pressure regulator and what it looks like..Cheers
Old Feb 23, 2006 | 08:24 PM
JesseT's Avatar
JesseT
It's the one also known as a warm up regulator:
http://www.specialtauto.com/images/warmup-136.jpg
Old Feb 25, 2006 | 12:49 PM
LEE-RS's Avatar
LEE-RS
Custom
not worth doing it imo if your gonna do it do it propper
Old Feb 25, 2006 | 10:20 PM
esccossie666's Avatar
esccossie666
think it will end in tears
Old Feb 26, 2006 | 11:14 AM
tonyturbo's Avatar
tonyturbo
it was good enough for turbo technics. me an a mate turbo'd an xr3i in 2 hours. janspeed exhaust, standard intercooler, t3 turbo, took head bolts out an slipped in a second head gasket for good measure, s2 oil feed, tapped a hole in sump for oil return(never removed sump)
drove well for over a month and boosted to 6 psi. turned boost up to 12 psi and it fell to bits around us!
Matt Baxter
Sep 16, 2015 08:30 PM
Dahl88
Aug 22, 2015 08:16 PM
A.t.p
Aug 15, 2015 11:37 AM
marky_g
Aug 15, 2015 10:43 AM
stevierob
Aug 11, 2015 09:08 PM
