what size nut an thread type for lambda sensor
Old Jul 25, 2004 | 09:22 AM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default what size nut an thread type for lambda sensor
got to weld one on the downpipe but need a nut to weld to exhaust first!!
i know they do a boss kit but cant be bothered getting one of them
Old Jul 25, 2004 | 09:29 AM
flashpoint's Avatar
flashpoint
18mm x 1.5mm
Steve
Old Jul 25, 2004 | 09:32 AM
Roosie's Avatar
Roosie
so its a 18mm inner diamiter thred or outer and whats the 1.5mm?
Old Jul 25, 2004 | 09:40 AM
flashpoint's Avatar
flashpoint
18mm is the outer diameter of the thread on the sensor, and the 1.5 mm is the pitch between the threads themselves
if you go into a good tool shop and ask for a nut 18x1.5mm they should able to point you in the right direction
or as I did get a tap and make your own
Steve
Old Jul 25, 2004 | 09:41 AM
NUTS RuS's Avatar
NUTS RuS
Thread size and pitch of thread
NUTS RuS's Avatar
NUTS RuS
too quick steve
Old Jul 25, 2004 | 09:42 AM
Roosie's Avatar
Roosie
cheers guys
Old Jul 25, 2004 | 10:26 AM
GARETH T's Avatar
GARETH T
it does depend on what lambda sensor you are going to screw into it!
if you are using it to set up a car, then yes its a m18x1.5
Old Jul 25, 2004 | 10:30 AM
Roosie's Avatar
Roosie
its a lambda sensor off a zetec escort and im using it for my afr gauge
Old Jul 26, 2004 | 07:20 AM
foreigneRS's Avatar
foreigneRS
Testing the future
then it's probably the smaller type (M12 x???). what size spanner do you need for it?
s1cab
Jul 26, 2018 06:11 PM
rst-s1
Aug 23, 2015 07:56 AM
Dahl88
Aug 22, 2015 08:16 PM
rdvil
Aug 15, 2015 12:11 PM
