Can anyone please identify these coilovers???
Old Jul 24, 2004 | 11:53 AM
SPADGE's Avatar
SPADGE
Default Can anyone please identify these coilovers???
These are the fronts on the track car i just bought back and i would like to know what make/spec they may be?
They have what looks like a Ford Motorsport part number on them being 9093162
Cheers Spadge...
Old Jul 24, 2004 | 12:27 PM
NUTS RuS's Avatar
NUTS RuS
Look like Bilstein to me
Old Jul 24, 2004 | 12:32 PM
Phil's Avatar
Phil
Jeebus
909 billys not the mag ones though!
Lets see this track car Spadger mate!
Old Jul 24, 2004 | 12:40 PM
NUTS RuS's Avatar
NUTS RuS
The damper rating should be stamped on the piston.
To get it out there should be a nut on the bottom of the strut, can sometimes be a pain to undo if they havn't been looked after. There should also be a small drain hole which usually gets blocked up, good idea to clean that too
Old Jul 24, 2004 | 12:57 PM
markk's Avatar
markk
defo billys same as mine ! just a diff strut top m8 !!
Old Jul 24, 2004 | 01:09 PM
SPADGE's Avatar
SPADGE
Cool
I thought they may be Bilstein! They are just what i wanted before i decided to sell my car!
This nut on the bottom for removing them is a puzzle though as i thought i could just undo the pinch bolt as per usual to take them off?
Phil there are pics on another thread of mine from yesterday entitled "This car just wont die"
Cheers for your help fellas
Old Jul 24, 2004 | 01:12 PM
SPADGE's Avatar
SPADGE
Oh and whilst i'm talking about this car, what is a 2wd 3.9 rear diff worth???
markk's Avatar
markk
SPADGE,
you can !
the nut underneath is to remove the insert from the strut body !!
Old Jul 24, 2004 | 01:14 PM
markk's Avatar
markk
markk,
ive sold them for Ł120 all in !! plus delivery !! worth that all day long (that is unless i want to buy one then there Ł40 delivered !! )
SPADGE's Avatar
SPADGE
Originally Posted by markk
SPADGE,
you can !
Thought so Mark just Rus's post threw me a bit he obviously meant for removing the inserts!
Old Jul 24, 2004 | 01:15 PM
markk's Avatar
markk
Old Jul 24, 2004 | 01:16 PM
SPADGE's Avatar
SPADGE
Mark these restrictors on the turbo do i have to replace the comp housing to remove it? This has a Maram shafted T3 42/48 but has a tiny restrictor on the comp housing!
Old Jul 24, 2004 | 01:19 PM
SPADGE's Avatar
SPADGE
Thus
And i assume it will need re-mapping if i remove it?
Old Jul 24, 2004 | 01:24 PM
markk's Avatar
markk
no m8 just make a flange for the front
from this
havnt got any piccys of the flange on the front , if ya want to have a look ill go into the garage and take ya some piccys , but its just a bolt on flange to the normal 60mm or what ever inlet size you want to use ,
and yes a remap IS ESSENTIAL believe me , when kenny did mine we mapped it restricted 1st and all was sorted , removed the restrictor and it fookin detted like a bastard , fook all fuel at the top end m8 , as thats what the restictor does , just chokes the top end boost , had to put multipliers in at the top for 403's !! goes mint tho !
Old Jul 24, 2004 | 01:27 PM
SPADGE's Avatar
SPADGE
Cheers Mark
I don't know what i am going to do with the engine yet so i'll make the decision re-mapping when i do!
I have a standard comp housing off a T3 here would it not be easier to just bolt that on mate
Old Jul 24, 2004 | 01:29 PM
markk's Avatar
markk
probably if you have a spare
Old Jul 24, 2004 | 02:14 PM
TwoCossieBob's Avatar
TwoCossieBob
Default Coilovers
Hi Spadge
I told you they were 2 1/4 Bilsteins with tarmac 500lb rated springs on the fron and 400lb on the rear. The 909 part number is correct and they are standard fitment for a GRP A rally car unless you can afford a full magnesium setup.
I would be pleased to assist if you ahve any othe questions although it may be awkward to find a PC on holiday.
Good luck with breaking the car.
Regards
Bob
Old Jul 24, 2004 | 03:02 PM
SPADGE's Avatar
SPADGE
Default Re: Coilovers
Originally Posted by TwoCossieBob
Hi Spadge
Regards
Bob
Cheers Bob
I would have asked you but i thought you would have gone on your hols already!
Old Jul 24, 2004 | 03:05 PM
marco polo's Avatar
marco polo
Spadge
anything with the part No starting with 909 is ford motorsport
Old Jul 24, 2004 | 04:29 PM
RichardPON's Avatar
RichardPON
.............. and if you want to sell those billy shocks spadge, then let me know..........
Old Jul 24, 2004 | 05:49 PM
SPADGE's Avatar
SPADGE
They are for a 4x4 Rich so i doubt they would be much use to you!
I will be Ebaying them soon if i decide i don't need them
Old Jul 24, 2004 | 11:39 PM
NUTS RuS's Avatar
NUTS RuS
Sorry if I confused you about taking out the inserts to check for the damper ratings Spadge.
Of course to remove the complete strut you would just do it in the normal way
The restrictors my mate makes in the lathe for his cars are always done to a sweat fit. We have to heat up the housing to get them in then let it cool down around it afterwards. If it wont come out it could have been done like that
Old Jul 24, 2004 | 11:57 PM
SPADGE's Avatar
SPADGE
Cheers Rus
This restrictor is held in by a picnch bolt at the top and bottom as can be seen in the pic! It then has a piece of wire running through one of them with a seal on it a bit like the ones you see on gas/electric meters so i guess it should slide out if i undo those but the bolt holes will still be there so it will be just as easy to change the comp housing!
Old Jul 25, 2004 | 12:09 AM
NUTS RuS's Avatar
NUTS RuS
The tag is a scruitineer checking item. It shows if the restrictor (or turbo) has been tampered with after its been checked with their verniers for size compliance.
It will have some numbers / markings on it which can be traced back through the powers that be if the car has a motorsport log book.
A taper threaded plug is sometimes used to bung up the holes left by these sort of grub screw restrictors after removal.
Are you gonna use it (the car) or break it ?
Old Jul 25, 2004 | 10:38 AM
markk's Avatar
markk
get it rallied , dont breakit have a go at some real motorsport , even if you only do it once , the rush just cant be described m8
its like nothing else waiting on the start line with the clutch down , legs shaking waiting to go , watching the clock waiting for ya time
if its msa logged then youre already there get a liscense , a navigator and your away !!
Old Jul 25, 2004 | 10:44 AM
NUTS RuS's Avatar
NUTS RuS
or hire it out
Mark are you looking at the Pendragon ? Me and Tim were discussing it yesterday, his entrys in already - Im not sure yet August is a busy month for me
Old Jul 25, 2004 | 10:56 AM
markk's Avatar
markk
NUTS RuS,
got some intercooling issues at the moment , just having one made at the mo , then i need to complete my firewall at the rear , so august is looking very unlikely at the moment , ive given up thinking about doing events until the cars completely done , i got sick of waiting for people / products to arrive , so i stopped thinking "id like to do that event "
jessie_rs
62
Aug 6, 2019 09:27 PM
mk1turboestate
Dec 2, 2015 08:31 PM
S3an
Sep 26, 2015 11:39 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
S3an
13
Sep 13, 2015 10:01 AM
