f**ked up big time
Old Jul 23, 2004 | 08:56 PM
bmwkiller's Avatar
bmwkiller
Default f**ked up big time
to cut a long story short, i was putting my head back on my erst after a rebuild and i snapped a headbolt in the block. is there anything i can do?
Old Jul 23, 2004 | 09:11 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
i did this once on a reno5turbo.
the snapped bit wont be tight, so just need a way of unscrewin it.
way i did it was drill a small hole in the headbolt, and hammer a slightly bigger bit of metal into the hole, allowing u to unscrew it, easy.
philipeddowes's Avatar
philipeddowes
take the head of and remove it or is at snapped at headgasket level?
How the fook did you snap one?
Old Jul 23, 2004 | 09:19 PM
DazC's Avatar
DazC
Let me guess....
You forgot to swap the washers onto the new bolts off the old bolts and it's bottomed out in the block and snapped?
If you have, good luck cos you will fooking need it!!! If not, get a pair of stillsons or vice grips and see if it will wind back out.....
Old Jul 23, 2004 | 09:20 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
i snapped mine halfway down the block! malfunctioning torque wrench
Old Jul 23, 2004 | 09:24 PM
philipeddowes
Take the head off get some grips and try to unwind it as Daz said
Old Jul 23, 2004 | 09:30 PM
bmwkiller's Avatar
bmwkiller
i think it might be my dodgy torque wrench, i did it all properly (i did swap the washers) last bolt on the end on the 3rd stage of tightening and snap! theres about an inch and a half still in there.
Old Jul 23, 2004 | 09:39 PM
DazC's Avatar
DazC
You would be supprised how many people forget to fit the washers!
Get the head off and some vice grips on it (tightly clamped on with PROPER vice grips and not these Ł2 market specials cos they're shit).
Old Jul 23, 2004 | 09:47 PM
bmwkiller's Avatar
bmwkiller
ok will do, ill let you all know how it goes tomorrow
thanx guys!!
Old Jul 23, 2004 | 10:46 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
or weld a washer on he top and itll be a pice of piss i took 2 heahily coroded in ones out perfect
Old Jul 24, 2004 | 12:34 AM
CabrioTurbo's Avatar
CabrioTurbo
as above it does depend where its snapped.. if its deep down in the block (which i dont imagine it will be as there would be no stress there then your fucked other wise if its at the top.. or if there is a bit protruding then it will be simple as. The head bolt itself wont be 'tight' in the block and should unscrew easily.. the only thing it torques down to is the head itself.
If it was me i would just cut a notch in the top with a hacksaw and unscrew it!
For gods sake cover the bores up when your doing this as you wont want swarf going into the bores
PaulinhoT
Oct 28, 2015 06:06 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Cameron
14
Aug 9, 2015 06:28 AM
Blown Hell
Aug 5, 2015 07:22 AM
