is this carb or single point injection?
Old Feb 14, 2006 | 04:57 PM
fiesta babe's Avatar
fiesta babe
Default is this carb or single point injection?
hi peeps need to know if this is carb or single point injection
and im guessing these are hydrolic lifters??
Old Feb 14, 2006 | 06:25 PM
Rs1's Avatar
Rs1
Carb and the hydraulic lifters are in the turreted looking casting of the head. You cant see them entirly but yep you are correct.
Rob
Old Feb 14, 2006 | 06:56 PM
HORNETS7's Avatar
HORNETS7
looks like a twin choke weber carb to me !!
with automatic choke !
Old Feb 14, 2006 | 07:13 PM
fiesta babe
okay got that out the way now this is the problem how do i turn down the mixture so it runs a little lean???
cant see any mixture screw on the side of the carb
Old Feb 14, 2006 | 10:54 PM
SafeChav's Avatar
SafeChav
I'd take it to a garage and slip them a tenner on the side to do it on a CO analyser, not the sort of thing u want to try and guess...........
Can i ask why u want to lean it down? Presumably running too rich?
Old Feb 15, 2006 | 12:10 PM
fiesta babe
i need to run it leaner as yes its over fuelling big time!! 1.4cvh and im getting 59 miles on Ł20 (tank isnt leaking fuel)
its the worst ford ive owned on fuel so far
got pulled over last night and had the lovely policeman jump out the car with a fire extinguiser he thought i was about to go bang judging from the strong smell of fuel coming out the zorst
Old Feb 15, 2006 | 12:12 PM
SafeChav's Avatar
SafeChav
I'd get it to a garage personally. I had an orion years ago with a 1.4 CVH and it was worse on fuel than the turbo'd one i had next, and it used to play up really bad some times, i think them carbs are a bit shit to be honest with you.
When did this problem start just out of interest?
Old Feb 15, 2006 | 04:13 PM
fiesta babe
dunno only had the escort for a few weeks we can get more miles out of Ł20 in da skyline and cossie
Old Feb 15, 2006 | 04:18 PM
SafeChav's Avatar
SafeChav
Well theres just an exscuse to drive them then, sounds good enough for me
Old Feb 16, 2006 | 04:05 PM
Dave Henshall's Avatar
Dave Henshall
could be the auto cold start choke - sticking shut so making it run righ - they are sometimes wax operated, so when the engine is hot, it opens the cold start shoke
Old Feb 16, 2006 | 04:31 PM
SafeChav's Avatar
SafeChav
Thats a good one never though of that, its coolant operated by the looks of it and it does look very crusty aswell....
Old Feb 17, 2006 | 09:35 PM
Stu @ M Developments's Avatar
PassionFords Creator
This is most likely the answer.
Especially is she seems to run a tad better cold than she does hot?
Old Feb 17, 2006 | 09:40 PM
HORNETS7's Avatar
HORNETS7
yeah and it works on water temperature u got some water in the header tank?
Old Feb 18, 2006 | 07:09 PM
FatLoss's Avatar
FatLoss
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
sridgett
Oct 1, 2015 07:30 PM
Orion_Gav
Sep 29, 2015 04:50 PM
