using bigger injectors
Old Jul 23, 2004 | 07:51 PM
nigel b's Avatar
nigel b
Default using bigger injectors
if you had higher flow injectors and the map was done on lower ones would you get loads of shite coming out the back
Old Jul 23, 2004 | 07:57 PM
Stu @ M Developments's Avatar
PassionFords Creator
Depends how much larger the new ones are..... Potentially yes, and the engine wont last too long either...
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
Fordmad!
Sep 29, 2015 07:03 PM
