F.A.O all series 2 owners urgent !!
my dads s2, standard discs and pads theyve hardly been used but the steering wheel judders like mad under breaking pointing to warped discs
is there anything else ie steering, brakes or suspension that could cause the wheel to shake ?
much apreciated...............matt
Knackered Steering Column Bushes would make it feel perhaps worse than it is, but if there is a wobble there, then it really needs to be found.
Mine used to judder like feck with EBC discs, but I don't have that problem now. So there's your answer, do a 330mm/4 Pot conversion.
just ordered some tarox discs and mintex pads for him
my old s2 used to judder too i know its a common prob but he has hardly used the car thats all
cheers guys................matt
Paul's got this prob mate - and can't solve it. It usually is the discs - even when not used much. The other main thing is TCA arms.
Matt - whats the diff between an S2 and sierra steering wheel boss? The wheel i got fits straight on, but has brought it forward and it feels stiff.
I'd say swap the disc's n pads out, u say u ordered sum, I had mintex pads, with Pagid disc's they were ok to start with, but I found that the mintex 1144's have a very hard compound and used to squeak like an arse! Took them off as they done my head in soo much.
i have black diamond discs and mintex pads, yeh the squeal is starting to get on my nerves now, i agree with you adam. what have you got now adam. ?
regards dave, ( deerhunter lost in crash)
I've got the same problem but i don't think it's the brakes.
Someone says to get the ball joints checked so that's what i'm doing as the brakes are still reasonably new
Posted: Fri Jul 23, 2004 1:36 pm Post subject:
Dave, well, I got my new rst and the brakes were fooked on it, I put my pagid discs off my old one onto it which stopped the judder I was getting and kept the standard pads in place as they have a fair bit of meat left on them. I think u will find the probs of squealing is the pads
Kiran1600E
11
Oct 2, 2015 11:35 AM
muz
Sep 30, 2015 08:29 AM
rsguy
44
Sep 29, 2015 03:29 PM
