Price for biggest brakes under 18" comp mo's - Mike R?
Old Jul 23, 2004 | 08:51 AM
Gadget's Avatar
Gadget
Spanner monkey
Default Price for biggest brakes under 18" comp mo's - Mike R?
As title please? making some enquiry's!
Old Jul 23, 2004 | 08:54 AM
Ryan's Avatar
Ryan
382 i think
Old Jul 23, 2004 | 08:57 AM
cfoster's Avatar
cfoster
you can get 382's under most 18's cant you??? I had them on me old escy!
Chris
Old Jul 23, 2004 | 09:01 AM
kjc300's Avatar
kjc300
362mm is the biggest that would fit mine!!!!
Old Jul 23, 2004 | 09:02 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Depends on your budget - 378 x 32s is the biggest size that will fit behind 18" MOs. Depends what sort you want, but expect to pay £3-4k for the top quality water-cooled ones. Probably get the budget "red" calipers / 378mm discs / brackets for around £2k ish.
The discs have to be floating though.
Old Jul 23, 2004 | 09:04 AM
wimwerf's Avatar
wimwerf
what is floating???
Old Jul 23, 2004 | 09:18 AM
Mike Rainbird
Caraholic
Instead of have holes in the disc where it mounts on to the bell, it has slots, where oval shaped bobbins are inserted (with bolts running through these). The bobbins are slightly smaller than the slot in the disc, which enables the disc a certain freedom of movement (hence "floating"). This is essential with such large discs, as the expansion and contraction would cause the bolts to shear. Also the leverage effect of applying the brakes would put a high load on the bearings and cause pad "knock off" (where the pistons are forced back into the calipers under hard cornering). This freedom of movement prevents this.
Old Jul 23, 2004 | 09:20 AM
Rene's Avatar
Rene
thanks mike
interesting read
Old Jul 23, 2004 | 09:21 AM
wimwerf's Avatar
wimwerf
thanks Mike.
Old Jul 23, 2004 | 09:26 AM
Paul Eggleton's Avatar
Paul Eggleton
THey make a bit of noise though which you have to get used to. Mine are 355's
Old Jul 23, 2004 | 02:24 PM
Sean Bicknell's Avatar
Sean Bicknell
It's not how big your disks are, it's how many pots your callipers have!!! Isn't that true Mike!!!
Mine are 380 x 32 Brembo jobbies!!
Plus these water cooled callipers, are they really at there best when not being cooled by water. I mean an old school 911 engine is designed to be air cooled and runs very well with out over heating with just air cooling. A bit like air cooled brake callipers.
We all know how we'd get on if we ran a water cooled engine with no water in it, as it's not designed for that it would overheat. Surely as water cooled callipers are designed to be water cooled, when no water is used is this not going to have a detrimental effect on brakeing performance. Of course I am talking about heavy useage here, and as Mike you will never go fast enough to get yours hot, maybe this will never be a problem for you.
Old Jul 23, 2004 | 02:29 PM
GARETH T's Avatar
GARETH T
i believe big brakes ISNT the way to go
is these brake rotors (which aint light) are acting as massive flywheels
Old Jul 23, 2004 | 02:32 PM
Mike Rainbird
Caraholic
Actually Sean, you should speak to Steve Scott, he now has the same 8-pot Brembos that you are talking about on his WRC rally car. His comments? They're nowhere near as good as his old WRC AP 6-pots (like I have on my car ) . So it proves that quanitity is not always as good as quality .
If you read the AP blurb, it is not necessary to connect the cooling part up - this is really only usually connected when the system is used by rally drivers that are doing lots of continuous left foot braking. I have yet to experience fade, and although my car might not be powerful enough to experience this, what it lacks there it makes up for in weight (bit like yourself ) .
Old Jul 23, 2004 | 02:34 PM
Mike Rainbird
Caraholic
Gareth,
This is true, I REALLY noticed the gyroscopic effect the larger discs had when I first put them on, but now I don't notice this effect - but the braking I couldn't do without now - it is truelly incredible!
Old Jul 23, 2004 | 02:57 PM
GARETH T's Avatar
GARETH T
i must be honest mike, i have never faded my 330mm rotors and 4pots,
Old Jul 23, 2004 | 02:59 PM
DaveEscos's Avatar
DaveEscos
are we talking about mike on his brakes? or mike on his missus! ;cry:
Old Jul 23, 2004 | 03:06 PM
Mike Rainbird
Caraholic
Gareth,
How many track days have you done?
Dave,
Old Jul 23, 2004 | 03:08 PM
GARETH T's Avatar
GARETH T
one in my cosworth
Old Jul 23, 2004 | 03:13 PM
Mike Rainbird
Caraholic
I rest my case .
Old Jul 23, 2004 | 03:27 PM
justin.e's Avatar
justin.e
so what you're saying mike is the 355's are best!
sean you can measure the car up at totb!going to use charge-cooler upgrade kit that i have in the garage,pump,rad etc.....
Justin
Old Jul 23, 2004 | 03:33 PM
Mike Rainbird
Caraholic
Justin,
Yes, as you can get away with running 17s!
Old Jul 23, 2004 | 03:34 PM
Sean Bicknell
Justin
Justin, I intend to be pissed all the way through the TOTB weekend. So then may not be a good time to ask me to measure anything!! Plus lets not forget its a Sunday and those are quadruple time where I come from.
Old Jul 23, 2004 | 03:41 PM
justin.e's Avatar
justin.e
sean,
fair enough!ill be there from sat afternoon so iam going 2 be well rubber!we could always get the ribena kid to measure up,that way we wouldn't have to jack up the car!lol...that right mike!...
RichardPON's Avatar
RichardPON
I wouldn't have said so.
Surely it's about pressure over a specific surface area?
I remember my GCSE Physics
Old Jul 23, 2004 | 03:44 PM
justin.e's Avatar
justin.e
sean,
Old Jul 23, 2004 | 06:59 PM
Sean Bicknell
I was pulling Mike's leg Rich as he always wanted 8 pots, but had to settle for 6's.
It's actually a lot to do with leading edges. The leading edge of the pad has a lot to do with the initial bite and feel when brakeing. The 8 pot Brembo's use 4 pads per calliper, hence twice the number of leading edges.
So Mike I have more pistons
and I have double the number of leading edges
yatta
May 21, 2016 10:31 PM
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
Tank Mike
Sep 14, 2015 03:56 PM
focus2351
Sep 9, 2015 09:33 PM
