Question on Running Cosworth BD10 Cams ????
Post Miester !
I am thinkin about running a Set or One BD10 cam in the cossie, Which is the better setup Both Cams or just one on the Inlet ?? I have heard that you get either more torque or BHP with one or the other setup is this true ???
Alex...
Alex...
Alex,
Dont do it!
Ask Dave Griffiths at Interpro about the saga when they fitted BD10's to my Bailey Saph engine (it was running STANDARD CAMS)........With the BD10's fitted I "lost 22 BHP and 28 ft LBS torque, verniers were fitted and dialed in correctly etc
The next day Dave fitted the STANDARD CAMS back in (no vernier required as thay had offset keys) and as if my magic all was well again: 408 BHP with 396 ft LBS on 26 PSI boost!
Dont do it!
Post Miester !
When the car is back on the road i am going to be running a T34, So i sounds like i will be better off running the Standard cams then because i am looking for a Reliable 330 - 340 BHP running less than 26 Psi Boost..
Al...
Al...
Al...
Al...
Originally Posted by Ima-Racing500
Doug you wont have dialled them in at the right setting mate,a very good set of cams to choose Alex
It was deffo in their interests to dial them in correctly!
Yes mate but do they know the right figures to dial them to????
Not being funny but i loved those cams and compliment the T4 well imo.
CUE Phil to respond with: "ahh, but the light blues are a 370 BHP injector"
Originally Posted by wimwerf
that's strange....you buy better cams and you lost bhp and torque. is it better to change only the inlet then to bd10 or what?
I am sure that our cam guru Karl Norris did confirm my findings on this subject on a prevoius thread
Phil,
Did you ever use standard cams with your set up? No - so shut the fuck up, you don't know what you're talking about
. Also, when when did you car ever run at it's full potential?
BD10s move the power up the rev range and would be even MORE shit on a T4 and loose even more response. Even Karl who is a fan of the BD10s acknowledges this
. BD10s move the power up the rev range and would be even MORE shit on a T4 and loose even more response. Even Karl who is a fan of the BD10s acknowledges this
I suggest sticking with the stand cams below 400bhp with a T3/4
I think my plan is to Get a New chip From Stu and run a T34 with standard cams.........
, Take the cheaper option...
Al.....
, Take the cheaper option... Al.....
Mine is standard cams, t34, and seems to work OK.
I am with Doug on the boost controller as well - soo much better with that on.
i have bd10s i never had a power run but felt sooo much quicker than cars with similar spec boost
No offence doug but my experience with interpro has been poor.
while dave offered some good advice he does not call the shots and i have allways found them to be money grabbing bastards.
On my fiesta they told me they couldnt do this and that due to the compression of my engine.
I just built that engine myself with parts new from ford so i took it else were and found there was no problem with my compression and was setup and released another 19bhp
i would only go there for a power run
they wont be getting any of my money again
i bought my engine with bd10s and verniers so im leaving it as is
i was on about my fiesta
but yes my engine is different from alex's
low comp greys t34
i wasnt arguing with mike or dougs comments baout the cams as tbh i havent gota clue
just the fact im not too keen on interpro
and similar spec cars with non low comp engines and similar boost have felt a lot slower to me
low comp greys t34
No steve the best bit later found there was a boost pipe hangin off jubly was done up on angle he said it was detting over 23 psi held and there was fuel so he said. So i was told compression of my car is wrong or my chip is tottaly wrong?and he charged me 500 to tell me that i infact had less power than when i went in.
JoeyBoyden
Jan 4, 2024 02:36 PM
Aug 14, 2015 07:29 AM
Roosie
Aug 13, 2015 07:40 PM
