YB Rear Crank Seal Installing Tool
Old Feb 12, 2006 | 10:30 AM
sevans's Avatar
sevans
Default YB Rear Crank Seal Installing Tool
Anyone know where you can either hire or buy one of these? The Workshop Manual quotes number 21-011-D. Found nothing on the web and the main dealers aren't much help.
Any help much appreciated.
Old Feb 22, 2006 | 11:20 AM
Adam Edwards's Avatar
Adam Edwards
Dont know where to get the tool but when you fit the seal be sure to use some sealant on the outside edge befofre you press it fully home.I had a problem with mine and it came out!You dont need the tool just make sure the seal is sat level when in and dont be afraid to give it a light tap with a piece of wood and a hammer.
Old Feb 22, 2006 | 10:19 PM
2001ode's Avatar
2001ode
Hi,
No need a special tool.
Just be carefull with lip, as usual.
Regards
Old Feb 23, 2006 | 12:24 PM
foreigneRS's Avatar
foreigneRS
Testing the future
you can use the backside of an old seal
Old Feb 24, 2006 | 05:06 PM
sevans's Avatar
sevans
Many thanks for the replies. Knowing my luck it will be a right bugger to fit and I'll end up damaging it. So a mate of mine is going to turn something out of PTFE to push the seal in. I'll put some sealant on the outside edge, thanks for the tip.
Old Feb 25, 2006 | 10:40 AM
stevieel's Avatar
stevieel
when I bought my full gasket set from cosworth, they supplied one of these fitting tools in the kit, try phoning them maybe they sell them separate and by the look of it they wouldnt cost much.
Ste
manuel boeckx
13
Oct 3, 2015 02:29 PM
xrmalin
Sep 13, 2015 06:52 PM
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
st220kyle
16
Aug 14, 2015 06:13 AM
