No NGK 9s so wot plugs ?
Jul 22, 2004 | 11:51 PM
Lewis told me they dont make these anymore
so what plugs for a cossie in the high 300's ?
greys low comp etc 28psi ???
car is now running but like a sack of shit got new ford leads so need new plugs asap
anyone ?
Jul 23, 2004 | 12:23 AM
I used to use Motorcraft PP 8 sparkplugs in my Esc. cos which were standard fit.
Some people on here don't like to use them but I can def. say they never gave me a problem.
By the way if you need a set I've got two sets up for grabs £ 18 set inc. postage.
Cheers.
Mark T.
Jul 23, 2004 | 05:38 AM
the NEW NGK9'S
Jul 23, 2004 | 06:32 AM
Do not use PP8S with 28psi
you can use C57s £25ish a set
Jul 23, 2004 | 07:26 AM
HKS S40's. Make sure the gap is 25 thou tho.
Jul 23, 2004 | 07:28 AM
AGP071s tested at 28psi and no problems what-so-ever. £20 delivered and I run these in my own car.
Jul 23, 2004 | 07:38 AM
Jul 23, 2004 | 07:46 AM
These aren't NGKs
. And at that price, if they only last 1/3 the life of the NGKs, you're still saving £10
Jul 23, 2004 | 07:47 AM
ah well you learn something everyday
Jul 23, 2004 | 07:53 AM
mike i have heard people using 9's for 25k miles, and the 071's are decent plugs but doubt they will last 8k
BTW Jayb has been running 57c's for 6k now
Jul 23, 2004 | 07:56 AM
PP8s/c59s are quality plugs if you want the electrode to come off at high boost/revs n fuck your engine
Jul 23, 2004 | 07:59 AM
Steve,
I have a mate who ran the 9s in his Stage 1 Escort for well over that mileage!
But I bet he would have got 8k no probs out of the AGP071s - it all depends on how hard you're using the plugs. I know they last longer than C57s though, so maybe Jay would have got 8k out of them
Jul 23, 2004 | 08:00 AM
Mike,
How much can you supply
AGPS071C 's for?
Am I right to assume that the "C" is a colder rated plug than the "S" suffex type?
BTW the AGPS071C plugs are the ones that The Harvester supplied when my engine was converted to 500 spec
Jul 23, 2004 | 08:01 AM
so why u running then them....
Jay is getting old LOL - m3 next then a vulva then retirment
Jul 23, 2004 | 08:05 AM
Dingy,
Because they are readily available and work perfectly and are cheap
Doug,
I was just being lazy, these are the 071s
. £20 delivered.
Jul 23, 2004 | 08:07 AM
Jul 23, 2004 | 08:09 AM
Really, NGK9's involves this...
I ring butch, he orders, they delivery, i collect, takes about 3 minutes.
Jul 23, 2004 | 08:10 AM
Steve,
Are these the correct NGK 9s though?
Jul 23, 2004 | 08:14 AM
Quote:
Doug,
. £20 delivered.
OK Mike, please supply me with 4 x AGPS071C plugs.
The only annoying "fault" with these plugs is the screw on top cap...I find that no matter how tight you put them on - they work loose with time, and "can" cause a misfire.....that goes away as soon as they are re-tightened
But I suppose at the price one should'nt complain
Jul 23, 2004 | 09:28 AM
splendid
mike can you pm me your bank details again and ill do another transfer for a set of these
Jul 23, 2004 | 09:31 AM
Jul 23, 2004 | 09:32 AM
Craig, checked the condition of the rotor arm and dizzy cap?
Jul 23, 2004 | 09:42 AM
Jul 23, 2004 | 09:44 AM
check the map sensor??
or is it missing????
Jul 23, 2004 | 09:45 AM
unsure yet
so many nigly little problems to sort
have had to re wire engine loom round the coil and it seems ok now
wanna replace the plugs anyway
slowly but surely
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
