fitting 18" on esc cos
Old Feb 11, 2006 | 03:02 PM
ian rst's Avatar
ian rst
Default fitting 18" on esc cos
I have some comp mo'2 in 18" with an offset of 30 so i have got a 5mm spacer and they are hitting the suspension cups? How can i get round this? Without getting bigger spacers? I heard you can hit the cup a bit?????????????
Old Feb 11, 2006 | 03:04 PM
kjc300's Avatar
kjc300
Have you got Koni's???
Old Feb 11, 2006 | 03:06 PM
ian rst's Avatar
ian rst
Yes mate
Old Feb 11, 2006 | 03:08 PM
kjc300's Avatar
kjc300
Aha!!
Well my spring platforms have been slightly fettled!! i.e. bent up out of the way, and sawn off!!!! lolol.
I believe this is a common mod!!!
I'll try and find a pic!!
Old Feb 11, 2006 | 03:15 PM
ian rst's Avatar
ian rst
cheers mate if you can find one thats would be good. Looks like i will take an angle grinder to it?
Old Feb 11, 2006 | 03:16 PM
kjc300's Avatar
kjc300
This is the only pic I have.
Basically the outer lip has been heated and bent up out of the way. Taking care not to impede any of the spring coils. I think the top of the lip has been removed so it doesn't hit the second coil up - if you know what I mean.
Old Feb 11, 2006 | 03:20 PM
ian rst's Avatar
ian rst
Blimey, ok so a bit of work needed. Thanks for that.
Old Feb 12, 2006 | 05:14 PM
Mark T's Avatar
Mark T
No problems getting 18 " wheels on this baby !.
Must be a Ford thing
[/img][/url]
Old Feb 12, 2006 | 05:42 PM
Fastmaul's Avatar
Fastmaul
K155MYRS
[/img][/url]
don't think soo...
Here's mine on 18's
And here's Nicks on 19's
Old Feb 12, 2006 | 06:14 PM
Mark T's Avatar
Mark T
Ha ha quality, must say respect to the black 3 door .
But the question is did the 19's go on without mods ?.
I'm guessing there was some work there.
Mark.
Old Feb 13, 2006 | 06:22 AM
Lmcarguy's Avatar
Lmcarguy
Yours looks nice on 18's, can you tell me the wheel ET and tire size you are running? Thanks
[/img][/url]
don't think soo...
Here's mine on 18's
Old Feb 14, 2006 | 03:06 AM
Fastmaul's Avatar
Fastmaul
K155MYRS
Mark.
Nick's going to have to answer that, Looking at your car it looks like it's still in stilts Lower that puppy.
Old Feb 14, 2006 | 10:30 AM
Mark T's Avatar
Mark T
Stilts maybe but at least they went straight on with no mods unlike some cars .
Can't be done with the lowering thing the handling is sh!t hot as it is and I don't want the hassle of having to tackle speed humps and driveways all the time, been there done that .
Lmcarguy if your question was aimed at me the ET is 48 and the tyre size is 225/40 18.
Mark.
Old Feb 15, 2006 | 05:14 PM
Lmcarguy's Avatar
Lmcarguy
Thank you Mark, I appreicate the reply, but my questions was for the cosworth with 18's, I wasn't very clear, I have since found my answer on another post by fastmaul. Thank you Lmcarguy
"I had to mod the front arches, but then again, I had 225 35 18's. Coilovers and 35 offset. The backs were fine and was using 245 35 18 with 30 offset. Yeah, little rub here and there but nothing to big, just no pie eaters in the back seats."
Mark.
Carlbacciochi
24
Jun 30, 2016 04:31 PM
y4n
Aug 17, 2015 12:12 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
cameron2
Aug 10, 2015 12:14 PM
ray barker
Aug 7, 2015 09:00 AM
