Dash lights
Old Feb 8, 2006 | 06:20 PM
xr_craig's Avatar
xr_craig
Default Dash lights
Any ideas as to why just the lights for rev counter/speedo etc would go out but the rest would still work fine?
xr_craig's Avatar
xr_craig
sierra btw
Old Feb 8, 2006 | 07:30 PM
cossied's Avatar
cossied
Default lights
check the big connector behind the clocks has not come loose.
Old Feb 8, 2006 | 10:03 PM
xr_craig's Avatar
xr_craig
cheers, will check tomorrow but would that not stop the rev counter working?
Old Feb 8, 2006 | 10:54 PM
cossied's Avatar
cossied
Default lights
depends if it just come loose, not fallen off all together
Old Feb 9, 2006 | 06:20 AM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
might be that the builbs are linked is series that means if 1 has blown may stop the rest from working
get multi meter ans check the 2 side s of the bulbs with ing and lights on
should be around 12 volts if not check fuses/wiring
tommy
Old Feb 9, 2006 | 08:35 AM
xr_craig's Avatar
xr_craig
cheers guys, will have a look in a bit.
IainRS1700T
Sep 25, 2015 06:44 AM
The Enigma
Sep 12, 2015 10:12 PM
imnoteasy
Sep 7, 2015 09:26 PM
