xr2i help
Old Feb 8, 2006 | 05:42 PM
shreevy's Avatar
shreevy
Default xr2i help
i have just replaced my service bits on my 1.6 cvh xr2i like cambelt,oil filter,fuel filter etc and then when i started it up the revs went really high and just stay there about 5000rpm.does this mean the timing is out or something else???
Old Feb 8, 2006 | 08:42 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
could poss mean that timing is out
but could also mean air leak in inlet manifold to idle that high try the vac hose that goes to the bake servo
also try disconecting the idle speed controll valve if it still revs high def air leak.
hope this helps
tommy
Old Feb 9, 2006 | 12:56 PM
cocaina_xr2i's Avatar
cocaina_xr2i
wrench it all
quick question mate where is ur idle speed valve? cus it may be cloged up u coul try taking it out take it a parts and clean it with parafine and WD40 did it to mine and it runs sweet now
Old Feb 9, 2006 | 03:34 PM
shreevy's Avatar
shreevy
its ok now thanks guys it was just that i 4got 2 reconnect one of the breather hoses.cheers anywayz.
cocaina_xr2i o and my idle speed control valve is on the back of the airbox
Andypandy260
Sep 23, 2015 10:28 PM
wildy
Dec 14, 2004 01:02 PM
Kelv
11
Nov 24, 2004 04:45 PM
fiesta_xr2i_guy
33
Oct 27, 2004 09:09 PM
lil rst boi
Aug 17, 2004 03:41 PM
