escos and saph cos gearboxes(mt75)
hello,was there any diffrences at all i think i saw somewhere something about the prop mounting bolts or someting being diffrent
later 4x4 boxe's had a longer shaft out the back of the box, the prop mounting bolt's, prop rubber & reverse switch are different, but can be swapped over, both boxe's will fit either escos or saphy with these part's swapped
