Had fuelling set up...melted a piston on the way home :(
Well not so much on the way home but literally within 2 miles of leaving
After dropping the car off to have the fuelling set up i drove home, and got 2 miles before it started pouring blue smoke from the exhaust all over the road.
Any ideas why this would happen?
Serious thoughts please
Iam hoping to get an engineers report first to determine what exactly was at fault before disclosing the name of the company as its only fair.
Just wondering wht everyones inclinations would be?
The car was a fieata turbo EFi, the fuel pressure was low and accordingly adjusted by aforemnetioned non-named company cause they said it was low, the car was in to be checked as the car had a engine fitted last year and never had the fueling checked so it was a precaution matter
the cars ONLY problem was a higher than normal idle to which wasnt solved either and the ISCV was unplugged instead as they had no luck setting it
im just looking for ideas what COULD have caused it
first things first - do a compression test - that will then rule out rings, piston and valve/guides failure.
If its the turbo rear oil seal that has failed, then it will smoke white at idle once the oil has warmed up, or if you are really unlucky, thick clouds of white smoke about 1 min after starting
As Chip said, if they've just upped the fuel pressure, it wouldn't of caused a real problem, unless you was proper hammering it on the way home, which, to be fair, most of us have done
What makes you say the piston is melted?
Which number piston is it?
What engine is it on?
other than that i cant say for sure its melted just that the road was covered in blue smoke when backing off and the breather is spitting out creamy goo
i was thinking of the fuel pump on its way out and upping the presure causing it to fail and melt BUT i never ragged it as i was litterally 2 miles from there and never went over 80 due to the area
would the fuel flow be tested if the fuel presure was seen to be low on a set up or not?
Shonky ofab/c mgmt!!! Now you know why I won't touch a car fitted with it!!!
On a serious note if you are running with the std fiesta turbo fuel pump then raising the fuel pressure can cause the pump seals to fail resulting in loss of fuel flow and melted engine.
This is more the fault of the pump than the person seting the car up, but only experience can help a tuner to know about this pump problem.
who can do engineers reports on here for a second opinion as im gonna fit a new engine and want to be sure this time, 3rd time lucky and all that ( on its 5th engine in its life )
it's all irrelevant what the fuel pressure was etc, what matters is what the AFR was. Also, if u were lean before hand, damage would have already been done, just happened to let go after the setup. Mahle pistons don't tend to melt for the fun of it.
rick would it not have gave up before though as ive had it running everyday since april when ginge fitted the engine and not had a problem, the boost has not been touched either just the fuel presure thats the part i find hard to take in, its been fine up until i went for it to be checked to be sure
Heat and fatigue will take they'r toll, and the engine will go at any time. I remember Matt Bell's old S2 letting go at a RR day (he wasn't running!) after it had been setup. It was running stupidly lean before hand, so it was a matter of time before it went.
Unless the car was tested under sustained load at high rpm, u can't really be certain of anything.
Is today the first day you have driven it in new trainers?
If so, it might be those to blame if it was fine wearing your previous trainers. Sue nike
i PAID for a set up, they checked the fueling as said the fuel presure was low, the turned it up
i have had the car running for 1 year and been having fun with it and the only problem i have had is gearboxes
NOW if you paied for your electrics to be tested on your house and they said the wiring seemed bad and so sorted it and the house then burnt down by what appeared to be a electrical fire would you not question it
thats what im asking here as i AM gonna get it looked at, it could be the fuel pipes are too small or the fuel pump is not flowing BUT thats why im asking is that not checked generally when the fuel presure is down
please remember that the car failed driving to the motorway and not on the motorway and not after i had been giving it beans, just started to smoke and got worse so i turned back like anyone would to be told that the injector could have failed or the fuel pump could just pack up
hope that explains more
if i paied for a set up and if failed due to a duff pump then would that not be part of what i paied for, just like checking if the fuel presure reg leaks ect
Originally Posted by JAMSPORT DAN
Does this mean that everybody with a fiesta turbo needs to worry about a blowup due to the cars standard ford management karl??
I have never had a problem with my managment i'd hardly call it shonky lol
Always thought OFAB was pretty damn good if you know what you are doing with it
And to be fair XRT si you can't hold the tuner responsible for the pump letting go, if this was the cause. Have you spoken to the company who set it up to see what they say about it all?
im not blaiming the company for the pump letting go, i want to test to see if that is the case, the car still runs right now but the engine is terminal
no refueling done either, just drove out and then it smoked and turned back, was literally like that
the company tbh didnt seem to be bothered and just said " turbo engines can let go at anytime"
not holding them responsible until i have all the facts as it could be just bad luck, just find it hard to belive im that unlucky that a car can run fine and just get checked and then die but im sure it does happen i supose
How anyone is supposed to tell that the old second hand fuel pump you have on your car is about to fail (should this be the case) is beyond me.
Sounds like you paid for your setup, they did the best they could for the money and budget etc etc and away you went with the car for somet else to fail.
IF
You'd taken your car to them for a new engine, new wiring, new pump etc etc then yeh their fault- or at least a manufacturer of the part that failed and I would expect them to help you out in someway.
They cant be expected to say yep all fine and nothing will go wrong with the car.
I would say its more coincedence than anything else.
When you're talking about modified cars anything above standard is a risk= yeh its well know that 170bhp rsts and 300 bhp cossies tend to go on for a while BUT they're still old cars with old wiring and old parts on them and as such NOTHING can be 100% unless it replaces with 100% new parts and then if you modify it past what it was designed for then theres still no guarentee.
We're lucky in that our cars come from a time when things were over engineered and then de tuned for road use.
How much did you pay for your set up out of interest.
best of luck
J
Folks, please I'm only taking the piss out of the fiesta mgmt!!!
Yes it is truely shocking in std form. I have never yet come across a fiesta turbo whether chipped or not that has'nt had some sort of fueling abnormality.
Yes I am taking the piss but it is with a serious hint! Ofab/c is shonky END OF STORY!!!
shings if they turned up the presure would that not then check the pump though, saying theres no way of knowing it would fail 5 mins up the road to a extent that totally melts down the engine under normal driving is not like it failing under load though
thats the part im questioning, as for the price of the set up thats irelevent too as i paied for a cars fueling to be checked and it melted 5 mins later
dont mean to sound arsey btw as i really cant be bothered to fit another engine and feel that if i ignored it i would still have a car running 1/2 a bar under fuel presure but never failed
just getting a idea of what people think as im sure if this was a cossie then more questions would be asked
its not a old car with old wiring aswell, its a converted car thats had new wiring on the pump but i could still be a design problem with the conversion hence me getting infomation of what to check first
shings i think thats a bit unfair to be honest
the engines MELTED its not failed, the fuel pumb would get worn and flow less surely and so that would idicate a problem, for it to melt driving home and not racing tells me theres something else there
he also got told the injector COULD have got a dodgy spray for a moment and would have melted the car,,,,,,,,, thats again not on a high speed run but driving on a 40mph road with 2 roundabouts between em
im more wondering about the fuel pipes and the fuel pump but to fail and that and NOT when it was being set up ( ie being ragged whilst looking at the fueling) makes me wonder
the turning up the presure as its low and the car to fail just sounds strange
maybe its just me but surly a set up for checking fueling would include checking the pumps flow ect ( btw they may have done that so not saying they havent
getting a car back that was inn for a MOT and then the cam belt lets go is bad luck,,,,,,,, get a car back from having a brake test and the brakes fail and cause you to crash is more what this is like tbh,,,,,, would you not wonder then ?
)getting a car back that was inn for a MOT and then the cam belt lets go is bad luck,,,,,,,, get a car back from having a brake test and the brakes fail and cause you to crash is more what this is like tbh,,,,,, would you not wonder then ?
Originally Posted by Replica
did they check the AFR with a proper wideband meter whilst on boost after they did the work ? could be they turned the fuel pressure adjuster the wrong way. doesnt take much to kill it !
