Brake Fluid master cylinder....
Old Feb 6, 2006 | 10:36 AM
playgirl's Avatar
playgirl
Default Brake Fluid master cylinder....
Hey
Is the Brake Fluid Reservoir/master cylinder the same on all Fiesta's or will I need to get one off a Fiesta RS Turbo?
Playgirl
Old Feb 6, 2006 | 04:56 PM
Manchester Mike's Avatar
Manchester Mike
I think they are all the same, sean got one for his recently.
They are cheap for the fez turbo anyway i think, sure he paid about Ł30 for his
Ł96 for the s2 escort though
Old Feb 6, 2006 | 05:59 PM
SafeChav's Avatar
SafeChav
The fiesta master cylinders are pea shooters man, im sure its fairly easy to upgrade to a mk5 escort item, brakes should be a lot better too
Old Feb 7, 2006 | 12:18 AM
snoozie76's Avatar
snoozie76
I'm 99% sure the master cylinders are the same on the XR and RS models but I'm pretty sure the master cylinder changes between the ABS and non-ABS models.
Think this was an optional extra on both models from new.
Could check this with your local Ford dealer.
muzzman1
Sep 30, 2015 08:59 PM
