RELAY CODE
Old Feb 5, 2006 | 05:58 PM
PAULDOLMAN's Avatar
PAULDOLMAN
Default RELAY CODE
hi guys,
i need the code for a relay on a fiesta rs turbo it's the one which controlls the interior & exterior fan i think it also controlls the front fog light as well,
i know it's got a tendersy to burn out from time to time
and also whats the origional colour of it.
thanks
PAUL
Old Feb 7, 2006 | 12:37 AM
snoozie76's Avatar
snoozie76
The relay for the interior heater is the green 'ignition' relay, numbered V on the main fusebox body.
Haynes manual says front fogs are relay C, dont know the colour thou.
I'm guessing there could be a poor connection on one of the connectors causing a heat build-up. it's probably worth a look.
And you could check for any corrosion on the metal bus-bar underneath where it connects to the power wires (red and blue ones). I had corrosion here on my car which stopped the heater working.
Old Feb 11, 2006 | 09:09 AM
fiestar5t's Avatar
fiestar5t
as bove mate its the green relay, i had the same problem with mine too!!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
