AFR meter....
Old Feb 5, 2006 | 02:21 PM
Default AFR meter....
....i have got in my secret car LOL a AFR meter its LED's i am assuming its a narrow band setup......of what possible use is it?..Is it at all useful? (possibly a weber alpha)
Old Feb 5, 2006 | 02:23 PM
Jay,'s Avatar
Jay,
Sponsor
phil in a word no unless its bin calibrated against a wideband
cheers jay
Old Feb 5, 2006 | 02:27 PM
......cheers i am used to the wideband motec gold box set up....so had never looked into the narrow bands.
Seems strange they are of no use i would guess the mixture comming out would show a vague idea surely?
Old Feb 5, 2006 | 02:29 PM
Jay,'s Avatar
Jay,
Sponsor
yeh but its a little like playin darts in a dark room lol
there just not the most accurate way of reading a afr
cheers jay
Old Feb 6, 2006 | 10:35 AM
bttt!
Old Feb 6, 2006 | 10:38 AM
Phil, they are of no use for mapping a car on boost, but are vaugely useful for checking that a car is running economically at part throttle.
People sell them because people buy them, not because they are very useful.
The narrow band sensor is basically only guarenteed as reliable as a switch around 14.7 AFR
So if will show you if you are above or below 14.7 AFR but it wont accurately tell you how much by!
Old Feb 6, 2006 | 10:55 AM
Jay,'s Avatar
Jay,
Sponsor
thats the term narrow band as will only read around the econ level of 14 to 15 afr it will give inacurate reading under or over that in most cases
cheers jay
Old Feb 6, 2006 | 11:06 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
What he said, just so you believe .
Old Feb 6, 2006 | 11:24 AM
Rick's Avatar
Rick
What they both said
Old Feb 6, 2006 | 11:29 AM
richm's Avatar
richm
Narrowband will clearly never be any substitute for wideband, and can not be considered as a tuning tool as such in that it won't indicate any sort of AFR accuracy except around 14.7:1 as already said..
BUT - if you take a wider view, it can be useful to tell you if anything is going wrong... if it's running rich on light load it will be obvious, if it's running lean on boost it will be obvious, by which i mean seriously lean... I've had a boost pipe come of the Fuel pressure reg. for example, or if the fuel pump has a big problem..
Old Feb 6, 2006 | 12:09 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
What about on a N/A car?
still useless?
Old Feb 6, 2006 | 12:14 PM
still useless?
Same applies really as with your foot down you will still be running richer than the rich end of the scale.
Old Feb 6, 2006 | 03:31 PM
So of use to actually detect a major failure before it happens!!! Thats all thats needed to know...this new car has one really neat install so i wont bother taking it out.
For serious stuff the GGR innovative wide band unit is being used
Old Feb 6, 2006 | 03:33 PM
Mike Rainbird
Caraholic
Which one, as the version that Stu tested in PF recently, wasn't particularly accuarate, and showed it being richer than it actually was...
Old Feb 6, 2006 | 03:35 PM
...whatever stu recommended i get!
Chas
Oct 5, 2015 07:13 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
Marino
Sep 12, 2015 11:10 AM
Red_bull
Aug 25, 2015 06:27 PM
Fiecos Dan
57
Oct 22, 2006 09:18 PM
