Hi
I've been reading through all the posts for a while and there is some great info.
Just wondering if anyone has any info on a steroid called Oxies, i'm gonna be trying an oral form of steroid soon, i was just gonna go with some T-bol but when i have rang my mate today he said he has been using Oxies and that they are the dogs bollox and i should give them a try, but i've never heard much about them.
Mate you obviously know nothing about this. Go read up first before taking things you dont know about....
ps its D-bol
ps its D-bol
Quote:
ps its D-bol
oxy's arnt dbol, they are much harsher than them, they are oxymetholone or the brand name is anadrolOriginally Posted by Ollie6RS2
Mate you obviously know nothing about this. Go read up first before taking things you dont know about.... ps its D-bol
http://www.steroid.com/Anadrol-50.php
Stu, your man Wally mentioned maybe doing T-Bol in his first post. I think you'll find thats what Ollie is referring to.
Thats the ones Stu.........Oxymetholone.Originally Posted by StuRST
oxy's arnt dbol, they are much harsher than them, they are oxymetholone or the brand name is anadrolhttp://www.steroid.com/Anadrol-50.php
They were stopped being used for severe anaemia around the mid 90's. The UK brand was called Anapalon 50. They are the strongest orals you can get and one of the strongest Anabolic Steroids you can get.
I used these a few years ago and gained 15lbs in 20 days. They make you feel like shit although the pump off them is unreal. Headaches, acne, gyno, upset tums are all part of the fun of this Steroid. I was using 50mg of Pro-v a day and then started taking Tam's aswell as I started to get itchy nipples......great sign that gyno is on its way! Luckily never got it!
If you want huge size and dont care about side effects then Anapalon 50 (oxy's) are the way!!
Originally Posted by Wallzyuk
HiI've been reading through all the posts for a while and there is some great info.
Just read this more carefully!!
Fuck me mate.......... dont go using Oxy's for your first course!!!!!!!
If you want to go the Steroid route stick with Dianabol or Winstrol.
Oxy's......you will get a shed load of sides plus you MUST take Proviron @ at least 50mg ed and Tamoxifen through the course.
Oxy's, Pro-v's and Tamoxifen will cost you £60-80 for a months course. You will gain shit loads but majority will be water that you will loose at the end of the course, gains you keep, couple of lbs.......is it worth it.............. no......I speak from much experiance!
Quote:
Originally Posted by Kieron
Stu, your man Wally mentioned maybe doing T-Bol in his first post. I think you'll find thats what Ollie is referring to. Cheers Kieron
Quote:
ok fair enough i read it wrong then Originally Posted by Kieron
Stu, your man Wally mentioned maybe doing T-Bol in his first post. I think you'll find thats what Ollie is referring to. but there is a compound known as T-bol (turanabol/turinabol) which is different to dbol http://www.steroid.com/Oral-Turinabol.php
you could describe it as dbol without the water retention, but you need to use a much higher dose to make it effective
3dr Cosworth owner
Originally Posted by godzilla
Thats the ones Stu.........Oxymetholone.They were stopped being used for severe anaemia around the mid 90's. The UK brand was called Anapalon 50. They are the strongest orals you can get and one of the strongest Anabolic Steroids you can get.
Good old nap 50's ol, These things sent me fucking crazy a few years ago, The testoterone boost i got made me very aggresive. Not a Roid id recomend to anyone really who wants to remain fairly normal. I couldnt control my temper at work and decided they werent for me.
There are loads of milder Roids you could try first.Like every1 else says. Do lots of research before you jump into anything. As for the Gyno godzilla is right. A few of us were taking these at the same time. One Guy was nearly in tears if you touched his nipples and another mate took them for a lot longer and ended up with boobies lol. Had to have an operation in the end for his Bitch tit
Godzilla knows his stuff and is very well informed with these things so take whatever he says as good information
