Fitness / Weight Training Discussions Don't drive around with 4 chins! Chat to like minded folk in here and get yourself back to a decent health and fitness level in no time.
what weight do you use with bicept curls?
Old 29-01-2008, 06:29 PM
paceo
paceo's Avatar
Default what weight do you use with bicept curls?
currently using 8kg worth of weights for my biceps with the dumbells, but its not hard to do, what weight do you use out of interest?
using 5 kg for forearm curls as well!
Old 29-01-2008, 06:39 PM
Paul Eggleton
Paul Eggleton's Avatar
I'm not as strong as I used to be but I currently use around 50kg on an EZ bar without swinging and cheating
If using dumbbells it would be 20-25kg depending on how I feel.
Old 29-01-2008, 06:49 PM
paceo
paceo's Avatar
well i used to be into it, but only just started, 8kg is way too light for me, thinking of maybe 15-20?
Old 29-01-2008, 07:54 PM
fast_ford_uk
fast_ford_uk's Avatar
how many reps can you do with 20kg if its between 8 and 10 per set thats spot on
Old 29-01-2008, 08:28 PM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
I rep up to 16kg and can just about manage 8 "clean" reps to failure on a good day.
Old 29-01-2008, 08:41 PM
alistairolsen
alistairolsen's Avatar
14kg, finishing on failure at ten reps ate the moment. After some reading I might drop from 20,15,10 to something like 10, 8, 6 and a higher weight?
Old 29-01-2008, 08:50 PM
Ollie.
Ollie.'s Avatar
20 or 22kg, 3 set of ten each arm. Then the same on hammers or cable curls with 30kg 4 sets to failure.
Old 29-01-2008, 10:27 PM
Muzz
Muzz's Avatar
20kg but i pyramid it with 12/15/17.5
Old 31-01-2008, 02:40 PM
Markb_s1
Markb_s1's Avatar
20kg here too
Old 31-01-2008, 04:25 PM
Kieron
Kieron's Avatar
Depends on exercise, 50kgs on an EZ bar with good form. 25Kg dumbells on seated or 30Kg standing curls. Like Paul though I have lost alot of strength.
Its all about what you feel comfortable with though. Dont go by what others lift. Whatever you can squeeze 8-10 reps out on with a struggle/spot.
Old 31-01-2008, 05:22 PM
paceo
paceo's Avatar
what is an ez bar? you mean a barbell?
done 12kg yesterday fairly easy, but im not pushing myself!
Old 01-02-2008, 03:53 AM
twoblacklines
twoblacklines's Avatar
an EZ bar is a barbell that has bent parts in the middle so you can isolate your triceps and biceps when you do pushups
Old 01-02-2008, 08:18 AM
Kieron
Kieron's Avatar
EZ BAR =
http://images.google.co.uk/images?hl...-8&sa=N&tab=wi
Old 04-02-2008, 05:37 PM
FAST AS FORD
FAST AS FORD's Avatar
55kg on an EZ bar, 28kg on dumbs, both 3 X 8.
Old 04-02-2008, 10:16 PM
dave cos4x4
dave cos4x4's Avatar
24-26-28, 10 reps.
but you do what you can do.
Old 04-02-2008, 11:15 PM
ESCYSCOTT
ESCYSCOTT's Avatar
14kg for 4 sets with good form - kills your arms
Old 05-02-2008, 01:42 PM
Donk1
Donk1's Avatar
i do 55 kg on the barbell and 25kg each arm on the dumbells, 4 sets of 6
Old 05-02-2008, 05:00 PM
danja
danja's Avatar
Managed 18kg 3 sets of 10 to failure point
Always manahed to get a good pump on my arms by doing higher reps on 12-14kg, felt awesome
Old 05-02-2008, 07:48 PM
ESCYSCOTT
ESCYSCOTT's Avatar
in my experience by lowering the weight you can concentrate on form and get a better "pump". Possibly more for definition too. Heavier weight for bulk though if you can lift it without swinging.
Old 05-02-2008, 07:53 PM
danja
danja's Avatar
Exactly what I was poitning out, works nicely eh
The good old swinging motion is a sure sign your lifting too much, if that aint a sign then putting your back out will be the next best thing, by then I think you will definately know lol
Old 08-02-2008, 08:46 PM
dave cos4x4
i do seated curls so its a bit more isolated.
Old 08-02-2008, 09:55 PM
danja
danja's Avatar
Ditto, erases the urge to swing the fuckers lol
That way, you only lift what your capable of, instead of whaling a load up and hurting your back...
wowk
30-03-2021 07:49 PM
3dr cossie
11
21-12-2015 03:38 PM
pabloXR
21-09-2015 12:42 PM
StephTell
Motorcycle Chat & Sales
14
02-09-2015 09:33 AM
Steve Escos
24-08-2015 07:56 AM
Quick Reply: what weight do you use with bicept curls?
