Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
'96 MK4 Zetec S Throttle Problem
Old Jan 13, 2013 | 09:40 PM
Jimbob2479's Avatar
Jimbob2479
Has officially lost it!
Default '96 MK4 Zetec S Throttle Problem
So on my mums MK4 Fiesta the throttle has all of a sudden just got really funny and thought i would ask you lot at PF your opinions!
When you put your foot on the throttle and apply a bit of pressure it starts to build up the revs as normal but if you put your foot down straight away, it doesn't rev up as it should it bogs out to below 1000 RPM and then starts to build up! Also if you put your foot down all the way before it gets to 3000RPM it will stay at 3.5-4000RPM and just rev at that max but if you do it slowly it will go all the way to redline!? Any help would be appreciated
Old Jan 14, 2013 | 01:55 PM
minder's Avatar
minder
it sounds like the flap in the throttle body is starting to stick easy fix just take the pipe off
the throttle body push the flap open with you finger (or get someone to push the throttle peddle) and just clean around the throttle body with carb cleaner or WD40
Old Jan 14, 2013 | 02:02 PM
Jimbob2479's Avatar
Jimbob2479
Cheers for this, ill give it a try!
muffster
13
Sep 3, 2015 09:40 PM
Bailes1992
Sep 3, 2015 02:17 PM
nick8saff
Aug 16, 2015 05:35 PM
A.t.p
Aug 15, 2015 11:37 AM
Sjieter
Aug 5, 2015 09:47 PM
