Superchip 165 or 195
How can you tell if a chip is a 165 or a 195?? i got a superchip off a friend and he did not know which one it was. There is no label on the back or front or anything???
Please help as i want a 195 not a 165 and if its the latter i will sell it
Cheers all
Cheers all
not sure if i tell you the mods i have planned what do you think it will be running at?
stage 2 pe hybrid T3 turbo, kent cvh34 cam, pro alloy front mount intercooler, superchip, cosworth induction, beige injectors, cosworth fuel pump, turbo and coolant hoses, s/s exhaust, felpro h/gasket with stretch bolts, paddle clutch.
Think tahts the majority of it, as you can imagine my c/c has had a battering!
st170 breaking
ahh well my point was gonna be that a 165 chip will let it boost to 15psi, a 195 to 18 i think (not 100 % on the 195) but with your spec i shud imagin you'd what to take advantage of more that 15psi
run it at over 15 mate, if it cuts its a 165 (or 15psi as i pref to say) if it dont its a 195
the boost limit seems to be teh only difference in my experiencs
you could just get it reflashed for 50 quid by a superchips retailer if it is just a 165
cheers thanks a lot for the advice, i see that it says on your sig that your car is going to the scrap have you done that yet? or any plans of stripping the car?
cossie09
11-10-2015 06:32 PM
