My new wheel's
The spec is as follow's
Engine: 1700 X/Flow stage 2 unleaded.
Bore +090 1686cc Fiesta.
Stoke standard.
Main bearings standard L/c material.
Big end bearings standard L/c material.
Thrust washer’s standard.
Crank standard linished fully balanced.
Flywheel balanced and machined.
Rods balanced end to end.
Pistons Hepolite balanced.
Camshaft piper BP285.
Timing chain morse H/D.
Tensioner pad and snail new.
Corplugs new.
XR2 sump and scavenger pipe fiesta.
Oil pump High pressure new.
Cam profile.
Power increase 18 to 20 bhp.
Duration inlet / exhaust 292 degrees.
Valve lift .430 thou 10.92mm in/ex.
Timing open/close 38-74 74-38.
Full lift at top dead centre 108 degrees.
Valve clearance 14thou .35mm inlet and exhaust.
Cylinder head fully flowed with three valve seats and mexico
inlet and exhaust valves double 285 springs.
Mk2 xr2 5 speed gearbox
Mk2 xr2 gear lever 5 speed
Chrome battery cover
Chrome suspension tops and nuts
Chrome coil can and bracket
K&N air filter
Full stainless scorpion exhaust
Blue distributor cap
Bodywork: Fiesta base model shell re-sprayed radiant red
Xr2 front and rear valences and arches, which have been modified
Xr2 front bumper, which has been cut,modified,filled and colour coded
Xr2 rear bumper with relocated number plate light, which has been filled
and colour coded
Xr2 boot spoiler which has been colour coded and blended to the car
and washer jet hole filled
Smooth boot lid with bodyline de-locked
Doors de-locked
Colour coded wing mirrors
Headlight eyebrows colour coded
Front grill colour coded
Bee sting aerial
N/S fog light added
Clear indicators
Clear side repeaters
Standard rear light's half tinted
Single wiper
Brakes: Front:Xr2 disc, pads and callipers
Rear: Fiesta-centre rear disc conversion
Good ridge braided brake hoses all round
Callipers painted blue
Willwood brake bias valve
Interior: Xr2 dash, which has been paited black and modified for gauges in
Centre air vents
Xr2 Centre console, which has been painted, black and modified
for brake basis valve and boot release switch
Gear lever cut down
Carbon fibre and blue gear knob
Blue gear lever gator
Roof clock
White dials with blue needles
Blue aluminium window winder handles
Blue cobra Monaco bucket seats
Blue sparco harness
Blue tax disc holder
Tim oil pressure gauge white face
Tim vacuum gauge black face
Tim volt meter white face
Carbon fibre gauge plate
Blue floor mats
One off front door cards made and covered blue
Back all boarded out and covered blue
Roll cage and door bars chromed
Rear strut brace
Xr2 steering wheel
Suspension: Fully adjustable spax shock's with 30mm lowering springs.
Stoke standard.
Corplugs new.
Cam profile.
K&N air filter
and colour coded
Doors de-locked
Bee sting aerial
N/S fog light added
Clear indicators
Single wiper
Centre air vents
Gear lever cut down
Roof clock
Blue sparco harness
Blue floor mats
Rear strut brace
Xr2 steering wheel
Adam Graham
06-09-2015 06:04 AM
