zetec-se 200+?
zetec-se 200+?
looking to get 200+ out of a zetec-se and so far all i've managed is to find more dead ends than answers
first idea was to go for throttle bodies and omex but on closer inspection it appears this will cost massively as in order for the rest of the car to be run i'd need to have a custom loom made and just generally redo pretty much everything, also was informed that the 210bhp tb'd se's are very hard to drive normally as they are extremely peaky and flat a witch's breasticle at lower revs
so onto idea no. 2 supercharging using a eaton M45 from a cooper s (very easy to get hold of due to my job ) so far as far as reseach all i know is that i will need:
supercharger +custom mounting brackets
bespoke crank pulley for the belt drive
bespoke intake manifold (looks like a right git to design and get made up)
larger injectors
low comp pistons
different cams (i'm right in thinking mild is best for forced induction???)
reworked head a possibility but not a necessity?
forged con rods
arp fasteners
some kind of head gasket to suit
Larger throttle body
Intercooler
all pipework
larger fuel rail with rising rate fuel reg?
better fuel pump
then of course the whole management and loom issue
which i am really stuck with so if anyone can point me in the right direction or even give me some advice on what i can do to pull this off (200bhp+ and reliable/everyday driveable) it would be much appreciated
thanks
Lewis
larger injectors
low comp pistons
forged con rods
arp fasteners
Intercooler
all pipework
better fuel pump
thanks
Lewis
Originally Posted by warrenpenalver
Speak to Owen Developments as they have worked on 2 turbo zetec-SE based on puma 1.7 lumps.
VAD also did a supercharger conversion on a 1.6 zetec SE a while back.
also for the money i don't believe the VAD kit is particularly good using a decompression plate doesn't really instill confidence in me
however will see what owen developments say cheers for that
as for a turbo i was originally interested in this but for that it'd be probably more expense to build as i'd have to find a turbo to suit the engine and then buy it... (the supercharger was an eaton M45 from a cooper s as i already have access to a stock of them from works kit converted cars)
but i will bear that in mind .. also thought it'd be a little different to go for a supercharged 1600 as i think it would suit a front driver a lot more than a turbo (nice spread of power versus sudden spike??)
anyone else have any views or sggestions on this..
thanks
Lewis
Carbon Crazy
Tuning the zetec SE is not cheap to do especially if you want road spec and drivability.
Is it for your Mk6 fez?? If so you would be better off going the duratec route AKA ST150 as all the mounts etc are off the shelf and there is already easy tuning potential to 200+bhp NA and beyond with forced induction.
i do know where your coming from but it just seems like such an overdone route i mean the engine isn't exactly awe inspiring in standard form i test drove 1 and it just felt lazy i mean don't get me wrong it's fast all right but it never really feels like it's giving it's all
basically i want to work out how much it'd set me back to get more from the 1600 and then i'll try and decide if it's worth going that route as the duratec seems to have been adopted very quickly by tuning companies which i suppose is a plus point but theres so little available for the st it's ridiculous
am i mad?
got beaten by a new shape corsa today so feeling rather annoyed about the lack of power
so if i got the head reworked
larger valves
piper cams + verniers
4-2-1 manifold with sport cat and full miltek system
what sort of power could i reasonably expect to get?
also is an frp inlet a reasonably straightforward swap if i move the TB? is it possible?
larger valves
Carbon Crazy
I've just spent Ł6k on my 1.7 to get it from a 1.7 with exhaust up to 210bhp with throttle bodies, custom head and cams and omex 600 ecu. And thats with a second hand ecu and loom out of another Puma already wired up and with the correct map so no need for dyno time.
FRP inlet is a relatively easy swap but won't make a huge increase in power unless you have cams, exhaust and ecu map to boot.
The mods you suggest should give about 170bhp on a 1.7 with suitable ECU remap
hmmm well i've now done a fair bit of the work needed first with the miltek 4-2-1 and a 200 cell sports cat system however now have 120bhp and having major issues with the standard management throwing hissy fits (stuttering when cold etc) and overfuelling due to the mil light being on is getting a bit annoying
so far it's a toss up between:
dreamscience remap with the cams and a frp manifold (pumaspeed think it'd be easy to fit but i'm not so sure)
leave it be and buy something faster next year (quotes for a frs are alreayd pretty reasonable imo @ 1380 fully comp)
or bite the bullet and just get the frs engine put in there which at standard power etc is probs going to cost 4k ish region
on a plus the handling of the car is absolutely top notch so besides a brake upgrade that side of things i'm happy can easily handle it
anybody have any advice/ words of wisdom on this?
thanks
Lewis
thanks
Lewis
OldDan
04-03-2009 04:35 PM
