Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
I need some bushes............( and now I have them!!!!)
Old 08-10-2003, 12:38 PM
  #41
It's Czech Mate
It's Czech Mate's Avatar
They only had the later type tho.....
Old 13-10-2003, 11:17 AM
  #42
It's Czech Mate
Now I want to fit them.
I can see how to fit the bushes into the rollbar clamps at the front. Just a case of undoing the bolts and replaceing old with new.
What about the bushes from track controll arm to rollbar? Are these hard to do or it it jus the same, take off the nut ( sounds easier than it is I know ) and slide the new ones into place? or is it gonna be a bit more complicated?
Old 13-10-2003, 12:11 PM
  #43
paul cox
paul cox's Avatar
matt - you've got it right
the old ones will be a big to get out,you bay have to cut them out !!!!
the new ones - put in with copper slip,easier this way - they will be tight to do,may need a big hammer and block of wood !!!
Old 13-10-2003, 06:55 PM
  #44
Quickie
Quickie's Avatar
They are still available froms ford as well piece of piss to fit
Old 13-10-2003, 07:34 PM
  #45
paul cox
paul cox's Avatar
depends if matt has got ford items or polyflex (polyethene) bush's ???
fords - easy to fit
the others - take a tad of a to get um to fit
Old 13-10-2003, 09:58 PM
  #46
Quickie
Quickie's Avatar
I put gen ones in mine
Old 14-10-2003, 07:57 AM
  #47
It's Czech Mate
Ford ones......see top of thread.
Thanks for all the advice guys
Old 14-10-2003, 08:08 AM
  #48
paul cox
paul cox's Avatar
when you going to do them then ???
Old 14-10-2003, 08:20 AM
  #49
It's Czech Mate
Saturday.........if I can undo the bolts I'll let you all know how it goes!
Old 14-10-2003, 08:26 AM
  #50
paul cox
paul cox's Avatar
cool - get and spray WD40 on them now,okay.
if its like some of the bolts on my RSI - i had to warm um up with a bit of heat
Old 14-10-2003, 09:00 PM
  #51
Quickie
Quickie's Avatar
Rust on an RSi never
