erm ... might need some help ...
Old Nov 24, 2005 | 11:24 PM
Eagle's Avatar
Eagle
Super Moderator
Default erm ... might need some help ...
ok .. got the following ..
asus p5p800
80gig sata h/d
1 gig memory
but .. someone said i might have trouble loading xp as i need to load a raid driver ???? erm ..
also how the hell do you decide what cpu to use .. as this mobo has a few issues with certain intel p4's...
i need to know what bios i have to decide on what chip i can use ... but i got no idea .. cant get a p4 cheaply enough to just try it ... but i can do a bios update but need to get the system running first .. bloody catch 21 then
any ideas???
Old Nov 25, 2005 | 12:18 AM
SS1's Avatar
SS1
i pay somebody to build fix mine AND STILL GET PROBLEMS
but then its his problem not mine
so no not really
fucking pcs
but back to top
Old Nov 25, 2005 | 08:31 AM
DanRSturbo's Avatar
DanRSturbo
Pete,
At the start of installing XP it say's press F6 if you want to install a third party raid / scsi adaptor
As for the board, go for a cpu that doesn't have issues for a start then run a bios update if you want.
Search the net / forums for conflicts with that board and cpu
Again, option B) Bring it to Kent
Old Nov 25, 2005 | 08:51 AM
DanRSturbo's Avatar
DanRSturbo
Old Nov 25, 2005 | 05:09 PM
Eagle's Avatar
Eagle
Super Moderator
Originally Posted by DanRSturbo
Pete,
didn't bloody know that at the time did i
just was told its a good mobo ...
was lookin at a 530j p4 but that has issues with some bios
ok its a rev 1.01
do i need to have a seperate disc for these drivers dan ??? or will it be on xp ??
Old Nov 25, 2005 | 08:02 PM
DanRSturbo's Avatar
DanRSturbo
You will need to have seperate drivers to install it if it's the one you are planning on putting XP on it
Old Nov 26, 2005 | 02:15 PM
Eagle's Avatar
Eagle
Super Moderator
ok .. well tried it all last night .. no cup tho .. and the fooker dont start the psu ??? now all the other ones i have built start the psu going ... fooked off now .. might just get a decent mobo ..
any ideas dan???
is there any problems with mixing sata and eide ???
Old Nov 27, 2005 | 12:13 PM
nigel b's Avatar
nigel b
no problems mixing sata with ide
get the drivers off your mobo cd and put them on a floppy
your psu should start like normal(check the power switch )
Old Nov 27, 2005 | 08:03 PM
Eagle's Avatar
Eagle
Super Moderator
yeah .. thats what i thought nige .. i know its all connected up correctly ..
at least its not low on petrol ...
Old Nov 28, 2005 | 10:30 AM
DanRSturbo's Avatar
DanRSturbo
What do you mean the PSU's not going ? As in, there's no power to it ???
Check the motherboard's not earthing out somewhere.
Old Nov 28, 2005 | 05:18 PM
Eagle's Avatar
Eagle
Super Moderator
found the problem with the power fookin knobs had put the wireing in wrong in the case .. on / off switch was connected to the reset wires
Old Nov 28, 2005 | 06:34 PM
DanRSturbo's Avatar
DanRSturbo
PMSL
mk22door
49
Mar 26, 2022 07:15 AM
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
ginger1979
Jul 31, 2015 09:56 PM
Stu.H
Jul 31, 2004 12:25 PM
