Networking PC's
Got 4 or 5 PC's in the unit all linked by cable to a hub.
Want to be able to access 1 of them - kind of run it like a server, from the others for stock control accounts etc PC's are seeing each other but its refusing access due to user permissions or something ?? There are no users set up on any :wall: Or is that my problem :cry: Ideally would like it setting up so as to have access to it from home too dial in access via the net. Anyone in the NorthWest can help me please :grin: Running Vista and XP :beer: Tony |
vista:
you have too open it in ehm.. file sharing permission/network permission/ firewall dont remember exact at the moment also, you need to share a folder, but surly you did understand that lol xp: it is open by default, but also here right click on the folder, properties, sharing, enable file sharing, allow user to change my files or something like that running zone alarm on any? you have to turn it off as it spoofs you computer/ or it spoofs your ports and block them then connecting to a folder //io on the machine you want to connect to/folder you have shared ex: //192.168.1.5/downloads to connect to a hard drive you have to in most ways add the $ like this //192.168.1.5/d$ then the easiest way to connect to it(if you only need files) is with ftp=) http://filezilla-project.org/download.php?type=server filezilla server free of charge its really basic thou, just click next on everything just remember the port that it is standing there, you can change that to what ever here is an other one that looks better imo http://www.freesshd.com/?ctt=overview download the sshd version just click next and ok on everything that pops up start it, you should see http://www.freesshd.com/Images/scrs1_large.jpg click where it says ssh at the top there select you ip then go where it stands sftp and select the folder/disk you want to share then click on the user: add users then to connect to the server from a ftp client add you username, password, select the port:22 (that is sftp) sftp: is encrypted so=) will advice you to download the filezilla ftp client as i can give you support on that;-) using linux to that stuff(ftp), and no not gone explain that :cry: can send you an other one on mail=) regarding the users on xp/vista sometimes (mostly xp) it want to connect as a guest disable the guest feature in users/control panel surly i have forgot a bunch here but it is a start oh.. hub... or a router with build in firewall? <--- if so, you need to open some ports to get connected and you pc´s, it can be running other firewalls, as a lot of the antiviruses have a firewall to |
| All times are GMT. The time now is 06:00 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
