vpn
Old May 3, 2007 | 03:22 PM
Eagle's Avatar
Eagle
Super Moderator
Default vpn
just had my pc tell me that vpn has been directed to 203.163.243.40
so does that mean i have a virus?? or have been hacked??
running avast peerguardian adaware etc etc etc
Old May 3, 2007 | 03:58 PM
cozmeister's Avatar
cozmeister
More boost Igor!
The first question is: Do you actually use a VPN?
If not, it's some buttmunch's idea for fun, so ignore it. Your computer won't tell you that your VPN has been directed anywhere, as IP address translation happens completely transparently to the user, and in most cases, the operating system.
If you do have a VPN connection, delete the connection and recreate it, ensuring that you enter the correct VPN server's hostname or IP address
Old May 3, 2007 | 04:13 PM
Eagle's Avatar
Eagle
Super Moderator
i have no idea if i have one
i have never set one up, just that the firewall alerted me to it asking if i wanted to allow traffic to go there.....
Old May 3, 2007 | 04:47 PM
cozmeister's Avatar
cozmeister
More boost Igor!
if you don't know if you have one, chances are you don't.
VPNs are used for connecting to other people's networks from remote locations, for example, using your work computer whilst sat at your home computer.
Block it and see what stops working - you'll soon find out if its something important, and then do all the ususal - check your AV and anti-spyware are up to date, then do a full scan to make sure you've not caught any nasties
After a bit of digging, that IP address appears to be located in India: http://wq.apnic.net/apnic-bin/whois....203.163.243.40
Unless you know anyone in India that wants to use your computer with your permission, block it, scan it, clean it
Old May 3, 2007 | 05:05 PM
Eagle's Avatar
Eagle
Super Moderator
have run norton and avast and found nothing no adaware results to worry about... firewall is on... best have a good dig round now... hhmmmmm
thanks for your help though mate
Old May 3, 2007 | 06:47 PM
Eagle's Avatar
Eagle
Super Moderator
bloomin thing is back
virtual private network traffic has been detected to 203.163.243.40
do you want to automatically set a rule to allow vpn communications with this server
checked everything, and found nothing...
Old May 3, 2007 | 08:46 PM
SS1's Avatar
SS1
Eagle
do you run win xp pro
Old May 4, 2007 | 02:35 PM
Eagle's Avatar
Eagle
Super Moderator
Originally Posted by avid-fan
Eagle
sure do ... oh god i can forsee summit comin now .. fully upto date all the updates installed....
Old May 4, 2007 | 04:06 PM
cozmeister's Avatar
cozmeister
More boost Igor!
First off, NO you DON'T want to allow it. Don't worry, you're not gonna have to wipe it and start again!
One more check that your computer's clean:
Goto your Network Connections control panel - you should have probably 3 icons in there tops: Make New Connection, Local Area Connection and your internet connection (which may also be called 'Local Area Connection' ) if you dial one with a modem.
Anything else, like 'Porn dialler', or 'XXX Boobs' etc can be safely binned.
Next, restart your computer in Safe Mode and get your anti-crap tools out - do a scan while in Safe Mode as this prevents the bastard programs from starting in the first place.
Whilst its scanning, have a beer and some grub then check your Startup Group ( Start -> All Programs -> Startup) and remove anything you don't recognise.
VPN connections don't just happen, unless someone at the other end is trying to connect to your computer thinking its a VPN server, or hoping its a VPN server that they can use to hack into a network. Either way - if you didn't start it, always block it unless you know what it is.
Old May 5, 2007 | 11:56 AM
Eagle's Avatar
Eagle
Super Moderator
yeah told it to fook off ...
has been ok today but will go and do a scan in safe mode see what appears
cheers mate
Old May 5, 2007 | 09:00 PM
Eagle's Avatar
Eagle
Super Moderator
nothing came up, even did an online norton scan just incase
bastard keep coming back though... have added it to peer guardian so it should not reappear i hope
Old May 6, 2007 | 09:57 PM
SS1's Avatar
SS1
Eagle
why i asked. is your computer remote access ENABLED if it is turn it off
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
