Wheels and Tyres Wheels and Tyres for all Ford's
Which is better for traction, R888 or R888R??
Old 25-05-2016, 09:55 PM
turbotrev
turbotrev's Avatar
Default Which is better for traction, R888 or R888R??
Which one is better for outright traction on the road, as in putting power down, not cornering and road holding, R888 or R888R?
Or is there not gonna be much difference?
They only seem to come in medium compound as well....
Cheers Paul
Old 25-05-2016, 11:34 PM
stevieturbo
C**t
stevieturbo's Avatar
I really doubt there would be much difference between them given the number of variables.
Car/engine setup would play a bigger part than choosing between those.
Old 26-05-2016, 08:21 AM
5hane
5hane's Avatar
A friend of mine is in the mr2 cup and gone from r888's to r888r's, they recon they perform very similarly. The main difference being the R888R's have a much better wear pattern, so should last a fair bit longer.
turbotrev (27-05-2016)
Old 26-05-2016, 01:04 PM
Caddyshack
Caddyshack's Avatar
Arent the R888R now the road legal version of the R888 thanks to some new euro law? I am pretty sure that is why they launched them, this would indicate that they are more road specific but it may just be down to them being able to comply with something the R888 can no longer hit.
Caddyshack
Caddyshack's Avatar
If they wear better then they are probably a harder compound I would have guessed?
Old 27-05-2016, 11:27 AM
turbotrev
turbotrev's Avatar
The R888's were road legal.
I used to run them.
I'm guessing the r888r's are just a freshened up revised version??
Cheers Paul
Old 27-05-2016, 11:28 AM
turbotrev
turbotrev's Avatar
I believe there used to be two compound versions of the r888's but I don't know if there is any more or on the r888r's...??
Cheers Paul
Old 27-05-2016, 04:39 PM
Caddyshack
Caddyshack's Avatar
Two on the r too but not in all sizes
Old 27-05-2016, 04:52 PM
turbotrev
turbotrev's Avatar
Is that listed on their website?
Cheers Paul
Old 27-05-2016, 05:03 PM
Caddyshack
Caddyshack's Avatar
Cheers Paul
They refer to it on their site but I could only see the one grade in the sizes I was looking at, you may need to speak to them or a good toyo dealer
Old 27-05-2016, 07:27 PM
stevieturbo
C**t
I used to run them.
Cheers Paul
And they still are road legal.
The issue if you can call it that is the arseholes in the EU, that because of noise/wear/efficiency bullshit if the tyre cannot meet their goals...it cannot receive an E mark and hence is not allowed to be sold for road use...which isnt the same as allowed to be used on the road.
But obviously not allowed to be sold for it's main and intended market does pose problems, hence the new tyre meets these silly new rules...for now.
Those are the only reasons the tyre changed
Old 27-05-2016, 07:37 PM
turbotrev
turbotrev's Avatar
I've sent them an email so I'll see what the reply is
Cheers Paul
Old 26-07-2016, 12:29 PM
5hane
5hane's Avatar
No I believe it is the construction, the r888's tend to balloon in the center,where as the r888r's don't and stay more square - so the center wears alot more linear with the outsides, rather than the r888's where the center will wear quicker than the outsides (keeping a close eye on air pressures at all times ofcourse!)
Old 26-07-2016, 05:45 PM
Caddyshack
Caddyshack's Avatar
Ah, makes sense. My old Michelin pilot cup sport 1's used to do that and go up by about 8 psi when warm on track so I had to set the pressures as 32psi HOT, if not you lost grip and wore the centres.
Ford Focus ST
78
17-07-2016 10:41 PM
steve w hebburn
Ford Focus Diesel
13-06-2016 10:15 PM
steve w hebburn
Ford Focus Diesel
25-05-2016 05:25 PM
rs_traynor
22-05-2016 12:19 PM
ByronG
17-05-2016 01:42 PM
Quick Reply: Which is better for traction, R888 or R888R??
