Trader Group Buys This forum is where our registered traders run their group buys. Come inside and sign up for a bargain.
Airtec 100mm Top Feed Intercooler Group Buy
Old 22-05-2012, 08:18 AM
  #41
James @ M Developments.
James @ M Developments.'s Avatar
The Escort fitment just requires the front crossmember to be cut to allow for the extra thickness of the cooler, Alan says its pretty easy to do, but unfortunatly due to the size there was no way of getting it to fit without having to cut.
All the intercoolers with 76mm outlets are not tapered.
And getting them with no scoop is no problem.
Old 22-05-2012, 09:36 AM
  #42
DaveCrack
DaveCrack's Avatar
Do you have the problem with needing to cut the bumper due to the air scoop only on 3drs or also on Saphs?
Old 22-05-2012, 09:38 AM
  #43
im sure the saff would need a trim aswell, but we can get them without the scoop
Old 22-05-2012, 09:44 AM
  #44
DaveCrack
DaveCrack's Avatar
Do you have any pics where it needs to be cut? if it's not visible from the front I'll be fine to cut a little from the back as the scoops for sure make sense.
Old 22-05-2012, 12:03 PM
  #45
Sonic Boom
Sonic Boom's Avatar
Ok cool James put me down for 1
Rich
Old 22-05-2012, 12:10 PM
  #46
so thats 1 left!
Old 22-05-2012, 12:15 PM
  #47
Sonic Boom
Sonic Boom's Avatar
Sorry to ask another question but will the angle the outlet so it lines up with my Hart inlet manifold too?
Rich
Old 22-05-2012, 12:21 PM
  #48
they do a fitting kit which drops the cooler to line up with those plenums.
Old 23-05-2012, 08:12 AM
  #49
Ive asked Alan this question, he says the scoop is 2" deep, so it wont take much trimming to fit, and shouldnt be visable from the front.
Old 23-05-2012, 08:21 AM
  #50
So far in the buy we have
Sonic Boom
Davecrack
Gav Diamond
Double-a
Old 25-05-2012, 09:12 AM
  #51
Come on guys!
One more and we can get this group buy done!
Old 25-05-2012, 11:34 AM
  #52
DaveCrack
DaveCrack's Avatar
Anyone?
Old 28-05-2012, 08:15 AM
  #53
Upski! Will be getting sorted this week!
Old 28-05-2012, 08:50 AM
  #54
OK,
for those of you who are in this group buy i have sorted the discount code for you,
please log into the webshop and use discount code "Airtec100"
www.shop.motorsport-developments.co.uk
The coolers will then be ordered and made to your spec. Please remember to order any fitting kits, or state in the notes section if any mods are to be done to the cooler IE no air scoop etc etc.
Old 28-05-2012, 11:17 AM
  #55
double-a
Cheers. Aaron
double-a's Avatar
thanks james
payment sent mate but it came up with another discount code automatically when i entered airtec100. not sure but ive paid anyway
cheers
Old 28-05-2012, 11:30 AM
  #56
Problem sorted, you have a pm mate.
Old 30-05-2012, 10:39 AM
  #57
Up for payments please!
Old 30-05-2012, 12:53 PM
  #58
Miller 3
Miller 3's Avatar
Yer you bunch of C#*ts lol
Old 31-05-2012, 10:31 AM
  #59
B13 JUS
B13 JUS's Avatar
no sure why brammer had to cut his bumper but mine was ok with no bumper mods
the scoop should have been made wider though so it went round the bumper instead of fitting up to it.
like this.....
Old 31-05-2012, 01:22 PM
  #60
RONNIE AMIS
RONNIE AMIS's Avatar
Justin do you have a 500 bumper or standard?
Old 31-05-2012, 03:27 PM
  #61
BRAMMER
BRAMMER's Avatar
I have pulled my bumper as far forward as possible, that far i had to remove the wring clips from the rear of the crossmember
I notice Justins scoop is riveted on - mine is welded as i would have just removed it but that must be a new addition as mine was one of the first batch for sale
Old 31-05-2012, 03:29 PM
  #62
DaveCrack
DaveCrack's Avatar
Thanks for the quick service as usual!
Old 31-05-2012, 06:44 PM
  #63
RWD_cossie_wil
RWD_cossie_wil's Avatar
Ok, I will take the 5th one please, for a saff, let me know about payment
Old 31-05-2012, 10:18 PM
  #64
Sonic Boom
Sonic Boom's Avatar
I will still have mine but due to my recent engine failure i've forgot all about it.
I'll sort payment out tomorrow.
Rich
Old 01-06-2012, 08:31 AM
  #65
You two guys can just log in and buy one on the webshop using the discount code!
Old 01-06-2012, 10:38 AM
  #66
KSA-Cossie
KSA-Cossie's Avatar
I have a radtec turbo cooler on my saph, what do I fix it to if I take off my radtec cooler and fit the airtec one ??
Old 01-06-2012, 10:58 AM
  #67
does it mount to the intercooler? or the rad?
you may have to just fab up some brackets to support it.
Old 01-06-2012, 11:30 AM
  #68
KSA-Cossie
KSA-Cossie's Avatar
I'll need to take a look and see James
Old 01-06-2012, 11:31 AM
  #69
ok, if you want one let me know and ill sort it for you.
Old 01-06-2012, 05:13 PM
  #70
leo_cos
leo_cos's Avatar
how much is the fitting kit and wat involved in fitting to an escos
Old 02-06-2012, 08:53 AM
  #71
BRAMMER
BRAMMER's Avatar
Best thing to do is speak to Alan regarding the Escos - i know one of the mods is cutting the crossmember out but if you went that far you may as well go for the 120mm version
Kev your Turbo cooler should already be mounted to your rad so no changes should have to be made for fitting this cooler - the turbo cooler should work a lot better as theirs no obstruction
Here's mine fitted with a 60mm Airtec rad & Airtec 60mm turbo cooler & 100mm cooler
Old 02-06-2012, 10:30 AM
  #72
B13 JUS
B13 JUS's Avatar
standard bumper, thats why i thought the scoop should have been wider? the scoop will be missing alot of air how it is
Old 02-06-2012, 10:33 AM
  #73
B13 JUS
B13 JUS's Avatar
not sure why but my bumper will fit in the same place as before. if you measure your scoop depth i will measure mine and see if there's a difference.
Old 02-06-2012, 12:46 PM
  #74
KSA-Cossie
KSA-Cossie's Avatar
Thanks Chris, looks like I'm in then lol
Old 07-06-2012, 08:42 AM
  #75
Dive on the webshop and get one mate!
Old 07-06-2012, 06:35 PM
  #76
Sonic Boom
Sonic Boom's Avatar
Ordered mine on Tuesday
Rich
Old 10-06-2012, 09:39 PM
  #77
RWD_cossie_wil
Ordered ... Stop doing theese group buys FFS they are costing me a fortune
Old 13-06-2012, 01:46 PM
  #78
DaveCrack
DaveCrack's Avatar
Intercooler arrived here on monday and looks very nice! Hope it also doe it's job the same! Thanks again for the great service!
SmudgerByName
52
28-07-2016 06:14 PM
23
12-09-2015 12:56 PM
FlashRS
13
31-08-2015 06:02 PM
Bailes1992
16-08-2015 07:14 PM
Quick Reply: Airtec 100mm Top Feed Intercooler Group Buy
