Fiesta brake light wont go out!!
Old 08-11-2005, 05:02 PM
OwenGsi
OwenGsi's Avatar
Default Fiesta brake light wont go out!!
Got a little fez (N Reg) as a runaround and the brake lights are permanently on! I'm guessing its a faulty switch or bad earth and hoping someone can point me in the right direction as to where to start looking
Old 08-11-2005, 05:31 PM
rapidcossie
rapidcossie's Avatar
there is a switch at the pedal try that
Old 08-11-2005, 05:41 PM
HORNETS7
HORNETS7's Avatar
as above the pedal switch has worked loose it should touch the pedal then when u press the pedal down it releases the switch out
Old 09-11-2005, 05:38 PM
OwenGsi
OwenGsi's Avatar
I've found the switch, but can't find a way of adjusting it (no torch, dark outside), any ideas as it seems well fixed and the washer typr bolt on the underside of the switch wouldn't rotate to tighten (not sure if it should or not)
Old 09-11-2005, 05:56 PM
cossied
cossied's Avatar
Default switch
pull the connector off, if the lights go out then it is the switch.
Old 09-11-2005, 06:21 PM
rapidcossie
get sum blu tack and a 50p piece. push the pedal down and stick it between the pedal and the switch. problem solved
Old 09-11-2005, 06:23 PM
OwenGsi
OwenGsi's Avatar
i know its the switch, i pushed it in and the lights went out.
lol @ blu tack and 50p idea - class- but i think i'll key the surface of the contact plate and solder on a couple of washers or something
Old 09-11-2005, 06:26 PM
rapidcossie
seriously, the 50 p trick worked on my old fiesta.
Old 09-11-2005, 07:55 PM
OwenGsi
OwenGsi's Avatar
just been out and superglued a penny to the contact plate- sorted
my first mod on the fiesta and it only cost a penny lmao
Timmy74
Ford Mondeo Including ST
28-08-2015 01:21 PM
Quick Reply: Fiesta brake light wont go out!!
