Fiesta 2014 Air Con drain
Old 26-08-2016, 12:09 PM
adrianstudd
adrianstudd's Avatar
Default Fiesta 2014 Air Con drain
Hi, I have a 2014 Fiesta Titanium 1 litre econotec, the front carpets are wet and starting to smell, taking off the drivers side panel beside the centre console I can see that the evaporator is leaking clean water, presumably the condensate, but no apparent drain! There is a small stub with a cover and when this is removed water flows from it, but this doesn't have a drain tube attached, should it? No water apparent under the car as would be expected. Where should the condensate drain be?
Thanks
Adrian.
no1fanofcolin
21
08-04-2016 07:45 PM
paceo
23-03-2016 05:28 PM
RSmark84
28-02-2016 04:33 PM
Robski
Ford Escort RS Cosworth
17
04-12-2005 11:01 PM
Ford Classics & Vintage
30-12-2003 12:20 PM
Quick Reply: Fiesta 2014 Air Con drain
