Rs turbo front gaz coilovers
Please can someone help to explain what way the bearing and other bits go on top struts step by step , they come with a copper thick washer as standard where does that go etc
Cheers anyway think sorted it bearing first then washer on top then big cap then screw down with nut everything moves freely then ,like it should any other way causes it to go tight then be a problem when turning clonkin etc
