very very! strange coolant issue with cosworth YB
Old 17-06-2016, 07:37 PM
carterhall14@hotmail.com
carterhall14@hotmail.com's Avatar
Default very very! strange coolant issue with cosworth YB
new water pump, thermostat, new alloy rad, new hoses, new header cap, new head gasket, head all tested, matrix checked ok, bled the system numerous times, no blockages, but the coolant will not flow the water always stays freezing cold in the header tank it never pressurises or boils over and the temp gauge goes through roof, any professionals who can crack this issue?? thanks. seriuosly i challenge anyone who can figure this!
Old 17-06-2016, 07:51 PM
Caddyshack
Caddyshack's Avatar
If there is no flow I would try swapping out the water pump first and replace the thermostat.
Frustrating problem but will be simple. Why the change of this lot? I assume you know the head gasket is good?
Old 17-06-2016, 08:06 PM
hi yes fully rebuilt the engine so replaced everything for new peace of mind but that peace is shattered lol everything is brand new very frustrating indeed mate
Old 17-06-2016, 08:09 PM
Caddyshack
Caddyshack's Avatar
It will be something silly. You will need to re check everything, maybe the wrong stat or something
Old 17-06-2016, 08:10 PM
yeah mate i will try running it without the stat and put another pump on see if the problem sorts itself thanks bud.
Old 17-06-2016, 08:41 PM
RichieST
RichieST's Avatar
It may sound simple, but make sure the thermostat is fitted the right way round.
Old 17-06-2016, 08:47 PM
Dezzer
4x4 resto
Dezzer's Avatar
Did you leave one of the plastic bungs in the radiator outlets by accident !
Old 17-06-2016, 09:26 PM
cheers for the replies lads, yeah i will double check the stat and no mate the rubber caps were off .
Old 17-06-2016, 10:50 PM
markk
markk's Avatar
Put some engine bay pics up.
Is it 2wd?
Old 18-06-2016, 07:56 AM
2wd, all the plumbing is correct. ive had garages/mechanics scratching their heads at this one nobody can work out why its behaving this way.
Old 18-06-2016, 01:47 PM
checked stat its in correct. and i bought the new water pump a while ago but cant remember if it was a pinto one i bought because everybody told me they fit? its not the open vane one..
Old 18-06-2016, 01:59 PM
markk
markk's Avatar
Take a pic and post it, I might be able to help but need to see the engine, especially the pump
Old 18-06-2016, 02:10 PM
hi mate, im not with the car now but ive brought the pump home with me heres a couple of pics..
Old 18-06-2016, 02:14 PM
markk
markk's Avatar
Have a look inside the main hose feed, yours has the correct impeller, but not the right housing (not always important).
Can you see right inside the hose flange to the spindle?
Old 18-06-2016, 02:18 PM
thanks heres a pic mate
Old 18-06-2016, 02:35 PM
you rekon this pump is up to the job? or shall i buy genuine? thanks mate.
Old 18-06-2016, 04:02 PM
markk
markk's Avatar
That pump should be fine.
I had one years ago that was not cast through, was no flow passage into the pump.
Is the rest of the cooling system standard?
Old 18-06-2016, 04:44 PM
yeah mate the rest is standard, i can not get the water to flow through the small return from the turbo back to header even tried ypassing the turbo coolant its very annoying like mate.
Old 18-06-2016, 04:58 PM
Caddyshack
Caddyshack's Avatar
Got to be worth a new pump just to rule it out? You can always sell one if it isn't that
Old 18-06-2016, 05:16 PM
yeah i suppose mate thats what il do thanks.
Old 18-06-2016, 05:17 PM
Caddyshack
Caddyshack's Avatar
Some times with these thing you just need to change part by part.
The Cossie housing has a bleed screw so all east you can rule out an airlock there
carterhall14@hotmail.com (18-06-2016)
Old 18-06-2016, 05:22 PM
carl n 1977
carl n 1977's Avatar
Not sure if it's poss on the yb engine but have you put the head gasket on up side down and it's blocking the water ways from the head to the block
Old 18-06-2016, 05:34 PM
no mate its on correct
Old 18-06-2016, 06:37 PM
carl84
carl84's Avatar
Few things to check, stat is right way round, stat works and isnt faulty, try putting in cup of boilled water and see if it opens for rule of thumb, or putting old one back in if u have it, check for absructions / blockages in hoses /system ,or sender unit is faulty maybe and telling u engine is overheating when its not , have u got a itemp probe to check ,infra red gun to check engine temp , hop this helps ?????
Old 18-06-2016, 06:51 PM
mate the water isnt flowing the water stays ice cold in the header tank and there is no return flow at all.. its not a broken gauge. the stat is also in correct.
Old 18-06-2016, 07:57 PM
carl84
carl84's Avatar
Some engines youll get flow into header tank only when the stat is opened, might be worth checking the stat is actually working and not faulty as the symptoms sound like a sticking closed stat, if thats all ok do a snif test next ��
Old 18-06-2016, 08:09 PM
appreciate your input mate but the stat is working great been checked, as for sniff test the whole engine is rebuilt with everything tested before assembly
Old 18-06-2016, 08:16 PM
one thing i will add is that the brand new water pump does not spin freely. it isnt making noise/leaking or wobbly. if i try to spin in quickly and let go it stops if you know what i mean.
Old 18-06-2016, 08:22 PM
markk
markk's Avatar
That's correct.
Old 18-06-2016, 08:26 PM
thanks mate
Old 18-06-2016, 08:28 PM
tell you what like mate ive never owned a car like this its just battering my head now because ive changed everthing and the problem wont go away..
Old 18-06-2016, 08:34 PM
carl84
carl84's Avatar
Ok so your happy with, pump , and stat, hoses , air locks , so maybe check for an obstruction in new rad .? Keep an open mind and substitue things for known good parts if still available mate
Old 18-06-2016, 08:43 PM
costina
Live long and prosper!!
costina's Avatar
Blocked/corroded pipe on the side of thermo housing which is the flow to the turbo and then to header tank.
Just a thought.
Old 18-06-2016, 08:52 PM
thanks for the reply mate but they are clear ive flushed water through and it flows through the return into header but not under its own load.
Old 18-06-2016, 08:53 PM
its as if the water cant make it up the return line itself very weird
Old 19-06-2016, 04:10 PM
just to throw something else in here which i forgot to mention, the header tank im using is a CVH with the one bottom hose coming out and joining the t-piece in the lower rad hose. and the return coming from the turbo going to the small top outlet, also ive noticed the height of the header tank is lower than that of the cossie one. any idea if this would affect the flow?
Old 19-06-2016, 06:16 PM
this type
Old 22-06-2016, 10:25 AM
Adam-M
Adam-M's Avatar
The top connection on that header tank has a weird fitting sticking out that looks like it would stop the flow back in, can you post a pic of the engine bay?
Old 22-06-2016, 10:37 AM
Caddyshack
Caddyshack's Avatar
That is a reinforcement so that the plastic doesn't collapse when you tighten the jubilee clip up IIRC
Old 22-06-2016, 06:25 PM
here is a pic not the best but ive now bought the 4x4 header tank and just waiting on the roose conversion pipe to see if it makes any difference.
Quick Reply: very very! strange coolant issue with cosworth YB
