DEEP ECU wiring
DEEP ECU wiring
I've got a DEEP ECU for my silver top zetec for fitting to my MK3 escort, but can't find a pin out wiring diagram for it, even googling it. Anyone help?
Should be the same as the desk . One had a few extras like cruse control and the fuel computer. I can't remember which one.
Mondeo DESK ecu.
1 Battery 12v
3 Speed Sensor
4 Tacho
7 ECT Sensor
8 Fuel Pump Relay
9 MAF
11 Emission Canister Purge
12
13 Engine Coolant Fan Relay 1
14 Pulsed Secondary Air Injection
15 Engine Coolant fan Relay 2
16 Earth
17 Data Link
18 Engine Diagnostic Connector
19 Engine Diagnostic Connector
20 Current Return
21 Idle Control Valve
22 Fuel Pump Relay
23
24 Camshaft Position
25 IAT Sensor
26 TPS
27 EGR
28 PAS
29
30
31 Engine Coolant Fan Relay 3
32
33 EGR
34 Digital Multifunction Display
35 Injector 4
37 Engine Control Relay
38
39 Injector 3
40 Earth
41
42 Octane Coding Plug
43
44 O2 sensor
45
46 Sensor Common
47 TPS
48 Data Link
49
50 MAF
51 Injector 1
52 Injector 2
53
54
55 Crank Position Sensor
56 Crank Position Sensor
57 Engine Control Relay
58 Ignition Coil 1&4
59 Ignition Coil 2&3
60 Earth
Mondeo DESK ecu.
1 Battery 12v
3 Speed Sensor
4 Tacho
7 ECT Sensor
8 Fuel Pump Relay
9 MAF
12
16 Earth
17 Data Link
20 Current Return
22 Fuel Pump Relay
23
25 IAT Sensor
26 TPS
27 EGR
28 PAS
29
30
32
33 EGR
35 Injector 4
38
39 Injector 3
40 Earth
41
43
44 O2 sensor
45
46 Sensor Common
47 TPS
48 Data Link
49
50 MAF
51 Injector 1
52 Injector 2
53
54
60 Earth
fray-bentos-uk (18-06-2016)
You don't really need it.
Fan relays, on some models there is a two stage fan and an extra fan for the Ac. The ecu controlled the Ac.
If you use an external fan switch then you don't need the above either.
I havnt just pulled this of the net. I pulled a loom to bits and traced it all out. I've done all sorts from the basic 2.0 pre pats 1993 Mondeo to the 2004 a Focus St170 and now the Focus Rs. I also have the st220 to look at.
Think so check the colour is like the other earths. There is a seperate one with a differant colour trace.
My Deep ECU has now arrived, but with no wiring plug (socket?), so I've got to adapt the old socket (TELL PATS) which I think I can do with all the much appreciated help on here. But can these pins with wires easily be pulled out and refitted to holes where previously there was no pin. Is it just a case of giving them a tug?
fray-bentos-uk (23-06-2016)
Ok, all going well, most wires now sorted. Can anyone confirm that the 4 injectors have a ignition switched + ve supply, and the ECU supply's the earth when required, or is it the other way around. Also does a 4 wire lamba have a permanent supply on the violet wire. Thanks.
The ecu switches the earth so yes switched 12v to the injectors, coil ect and the ecu fires them by earthing them.
The O2 also wants a switched live. This is for the heater and not the sensor.
VSS is electro mechanical.
Goes in place of speedo cable then speedo cable goes into VSS.
You can live without it. EEC may give trouble code for faulty VSS unless disabled in EEC software.
I'm all wired up now, but the engine is not firing, so I've decided to wire in the OBD connector to see what faults it gives. So the question is, how does the 16 pin connector wire in with a DEEP ECU.
fray-bentos-uk (28-09-2016)
Thanks for that jsa, so its ECU pin 18 to OBD pin 3, and ECU pin 19 to OBD 11. And I under stand OBD pin 4 is earth, and OBD pin 16 is permanent 12V supply. That's four wires sorted, how many more need connecting?
