Mk5 ZS conversion
Mk5 ZS conversion
I'm putting either a black top 1.8 Mondeo engine or a silvertop 2.0 litre engine into my mk5 fiesta . Any ideas on what engine mounts I will need that will fit straight in / or the ones I need to mod . And does anyone have a list of othe parts ( driveshafts , oil pick up etc )
Thanks In advance
Thanks In advance
STeve (12-06-2016)
Thanks In advance
Thanks In advance
I have a 2.0 blacktop turbo in mine. Custom engine mount. You need to decide if you want to run the standard gearbox, or upgrade. Standard is easiest as you then won't need to change the gbox mount or lower mount, and you can use your own shafts.
You'll need ideally an aftermarket ecu unless you want to faff around trying to merge wiring harnesses. You'll need a focus 2.0 waterproof to rad hose. Various PAS pipes. Focus exhaust downpipe. And a few more bits I've forgotten.
Matt
I'm going to use standard box after market Ecu . Do you have dimensions or photos of your custom mount . And what would I need to turbo mine . And what's your Bhp mate thanks cal
paceo
23-03-2016 05:28 PM
