Problems with auxility ( jackshaft ) bearing
Hello.
I need som good info how to mount auxility (jackshaft) bearing on my sierra cosworth 4x4.
I have boken 2 bearings under mounting.
So now I maid ĺ tool to mount the bearing with.
The 3 bearing is in the block.
But its not posible to mount the jackshaft.
The bearing is to big.
The bearing is ĺ Acl 5687 std DE 12
From burtonpower.
Not posible to get bearing from ford.
Have anybody some good way to mount the bearing, info on were to by ĺ bearing to fit.
Kind Regards
Vegard mikkelsen
Norway
From burtonpower.
Kind Regards
Vegard mikkelsen
Norway
Not quite understanding the problem ?
Are you saying the bearing is the incorrect size, and the auxiliary shaft will not fit in the hole ?
What is the size difference ?
Were the bearings installed correctly ?
carterhall14@hotmail.com
17-04-2016 07:07 PM
155lee
17-04-2016 02:01 PM
cossie91
16-04-2016 09:04 AM
