Zetec transplant questions.
Hi, I've got a 2.0 Mk1 Mondeo i want to transplant into a P100. For the meantime I want to use the origional injection set up but is this viable as is or do I need aftermarket management? Is there an Imobilizer in the Mondeo and if so can it be bypassed or brought to the P100?
Any help would be great.
Bring back old skool Ford
1995-1996 i think.
I took my 2.0 out of a 93 and there was def no PATS but im running bike carbs anyway. The original induction system is very restrictive
Dod IRL (04-04-2016)
Pats came in on the M reg, I don't know why people sweat it with the Pats. You can't bypass it but you can bring it to what ever your putting it in. Easy as. Give me Pats over pre pats any day as 97 on you get obd2 functions.
Assuming the donor is a manual 1993~94 then it will have one of three ecu's.
Deep, desk, dewy. If you can't find the pin outs give me a shout and I will see if I still have them on an old back up disk.
One I made earlier with a fiesta/escort inlet mani.
Just to show you pats is no big deal. St170 turned round on a t9 bell housing.
I am doing a turbo zetec with Rs management at the moment.
Dod IRL (20-04-2016)
Mondeo DESK ecu.
1 Battery 12v
3 Speed Sensor
4 Tacho
7 ECT Sensor
8 Fuel Pump Relay
9 MAF
11 Emission Canister Purge
12
13 Engine Coolant Fan Relay 1
14 Pulsed Secondary Air Injection
15 Engine Coolant fan Relay 2
16 Earth
17 Data Link
18 Engine Diagnostic Connector
19 Engine Diagnostic Connector
20 Current Return
21 Idle Control Valve
22 Fuel Pump Relay
23
24 Camshaft Position
25 IAT Sensor
26 TPS
27 EGR
28 PAS
29
30
31 Engine Coolant Fan Relay 3
32
33 EGR
34 Digital Multifunction Display
35 Injector 4
37 Engine Control Relay
38
39 Injector 3
40 Earth
41
42 Octane Coding Plug
43
44 O2 sensor
45
46 Sensor Common
47 TPS
48 Data Link
49
50 MAF
51 Injector 1
52 Injector 2
53
54
55 Crank Position Sensor
56 Crank Position Sensor
57 Engine Control Relay
58 Ignition Coil 1&4
59 Ignition Coil 2&3
60 Earth
1 Battery 12v
3 Speed Sensor
4 Tacho
7 ECT Sensor
8 Fuel Pump Relay
9 MAF
12
16 Earth
17 Data Link
20 Current Return
22 Fuel Pump Relay
23
25 IAT Sensor
26 TPS
27 EGR
28 PAS
29
30
32
33 EGR
35 Injector 4
38
39 Injector 3
40 Earth
41
43
44 O2 sensor
45
46 Sensor Common
47 TPS
48 Data Link
49
50 MAF
51 Injector 1
52 Injector 2
53
54
60 Earth
Just the one that's in your car. Yours should be one of them 3.
You get to it from the engine bay, behind the coolant expansion tank.
There will be a white sticker on the grey plug of the ecu with a four digit code. There are hundreds of them.
2.0 Zetec with T9 Rwd layout ready to go - YouTube
Budget St170 engine on oem ecu first full run. - YouTube
The st170 lump was set up for a kit car so it was a cut down sump.
I've done the cvh sump and it's naf. You have a better chance of winning the lottery than finding a 25 year old bit of Ford tin that only had half a layer of paint to start with then left hanging in the salt and elements since.
Even if you find one you need the pick up and spreader plates. It doesn't fit around the black top oil pump aswell as the silver top.
But yes it can be done.
A zetec / st170 cut and shut sump I did. If you can get the alloy girdle over the cross member the steel pan could be made any shape.
[/URL]
[/URL]
Was that successful? I'd be dubious about the lack of oil volume in the engine, but how did you find it? Also, I'm guessing you'd have shortened the Pick up as well?
Works fine, it's pretty much the standard height in a lotus 7 rep. It's the same depth as the bottom of the bell housing. The engine in a Mondeo or focus is canted forward so the pan is not flat when the engine is stood upright on a T9 or mt75. Besides where you remove volume you add some of it back where the exhaust runs.
Volume is around 4.1 L, add a cooler and it will take it over factory. Besides the oil gets changed much more often. As they do very little milage.
[/URL]
[/URL]
I have a PATS Zetec fitted to my mk3 Escort. Personally I would look for a PATs system as the inbuilt un-bypassable immobiliser is a welcome addition to keeping the car in my ownership.
I have a guide on my website that has some usefull info on electrics. For some reason I cannot get the direct URL up so you'll have to do a bit of navigating to get to it.
www.Auto-TaT.co.uk
click on the first (missing) picture to enter 'Escort Upgrades'
Click on 'Engine' from the left hand column
Click on 'Zetec'
Scroll down and click on 'Zetec ECU Pin List'
There is more info on that page than just the pin list, one of these days I'll get round to updating the thing. The wiring in of the PATS system and the diagnostic port are both covered.
Hope this helps.
www.Auto-TaT.co.uk
Click on 'Zetec'
Hope this helps.
hi.
a zetec in a p100 sounds really cool, mate!
i'm building something similar: a saph 2.0 silvertop from a 1.8cvh.
i was trying to use std mondeo ecu, but i had assembly issues between std intake manifold with 1.8cvh saph engine mounts.
s**ted myself off...
so the plan now would be going on with megajolt and bike carbs... but it might not be the best solution.
posting here my progress...just 'cause you might be interested.
https://passionford.com/forum/restor...-thinking.html
RSCossieGaz
14
27-03-2016 03:33 PM
original
Ford Focus RS Parts for Sale.
24-03-2016 11:08 PM
