focus rs brembo caliper brackets for a s2 rs turbo
Hi all . Got a set of focus rs brembo 4 pot calipers and discs for my rs turbo. Does anyone know which brackets I need to fit these ? Any modifications to the caliper etc ? I have 17 inch comps so wheel clearance is fine
I imagine it would be the same bracket as fitting them to sierra hubs, as the caliper bolt spacing it the same between escort rs turbos and sierra's, i fitted some to my 3 door replica and the only modifications I had to make was drilling out the bolt holes on the hub, a custom made braided flexible hoses and trim a bit of the caliper mount to clear a bolt that goes through the bracket and space the caliper to suit the disc, i havn't got any pictures of the brackets I used, what I will say watch though is your wheel offset because the caliper will sit a good bit further towards the face of the wheel
griffo69 (22-01-2016)
richbogle
12
26-01-2016 04:50 PM
mikers99
16
13-01-2016 01:12 PM
Mark RS
Alloy wheels and ICE for sale
07-01-2016 08:18 AM
