bosch 044 fuel pump running constant on prime
Old 19-09-2015, 11:47 AM
wheelwizardrefurbs
wheelwizardrefurbs's Avatar
Default bosch 044 fuel pump running constant on prime
bosch 044 fuel pump running constant on prime with ignition on it only does this when the engine is hot! could this be connected to my bad hesitation issue? cheers. sierra cosworth 2wd L6 ecu stage 3.
Old 19-09-2015, 03:22 PM
Im sure mine runs constantly sometimes too.
As long as your getting good fuel flow i cant see why it would cause the car to be hesitant.
When was the last time the fuel filter was change
wheelwizardrefurbs (19-09-2015)
Old 19-09-2015, 05:04 PM
Caddyshack
Caddyshack's Avatar
If the fuel pressure regulator was failing or set wrong then the pump could keep running ask it would be opening lower and running fuel back to the tank which in theory could cause an issue....I guess it would run lean? If you can swap out the pressure reg then it is one less thing to worry about but more expense....that or fit a gauge to see what it is doing?
Old 19-09-2015, 06:29 PM
wheelwizardrefurbs
thanks lads i have replaced the fpr already. also i put the multimeter on the fuel pump whilst the car is running and im getting 11.5v does this sound ok?
Old 19-09-2015, 06:34 PM
martysmartie
martysmartie's Avatar
The ECU determines the prime duration, which can vary with temperature, as such I would look toward the CTS, which would also cause running issues.
Martin
Old 19-09-2015, 07:06 PM
wheelwizardrefurbs
so how does the 11.5v sound? also its got a brand new CTS
Old 19-09-2015, 07:24 PM
tony66
tony66's Avatar
Default 11.5
its ok-but if you ran a thicker power wire and nice thick earth cables as practicable[switched] it would improve a bit
Old 19-09-2015, 08:49 PM
botters
competant bodger
botters's Avatar
i would want to see higher than 11.5 volt that will no doubt drop further under load
Old 20-09-2015, 10:37 PM
martysmartie
I would hope that is without the engine running.
Martin
Old 21-09-2015, 03:31 PM
wheelwizardrefurbs
with the engine running on idle martin
Old 21-09-2015, 07:51 PM
wheelwizardrefurbs
so i take it that voltage is really too low for the pump? you rekon that is whats causing the horrible stutter hesitating? also surley if i was not getting enough fuel i would be running very lean? yet my spark plugs are very sooty which would indicate rich? cheers
Old 21-09-2015, 08:10 PM
tony66
tony66's Avatar
Default 11.5 v
11.5 volts to pump shouldnt make it splutter but could be better[thats providing your alternator and battery are good]
run a good quality thick power cable to the pump[use an msd kit if you dont want to make one up-its not expensive] also make sure earths etc and any relays switching your pump on are fresh
it also helps to have a known good condition,quality fuel pump too
these are very old cars now and any replacement of the wiring done correctly always helps-some of the wiring was marginal when new-after all the years it doesnt get any better
Old 21-09-2015, 08:21 PM
martysmartie
Then yes that is too low, as mentioned that is without load, so it will drop further.
A melt down can occur as the result of this, you can't really tell by the plugs. Ideally you want to be seeing the power from the Alternator.
The wiring, along with the fans are two common problems, in this case it's due to the old wiring, which builds resistance with age.
Martin
Old 21-09-2015, 08:44 PM
wheelwizardrefurbs
cheers for the input lads, the alternator is brand new however it is a 65 amp dunno if thats a big issue? as i dont have heated screen etc. the fuel pump is a brand new bosch 044 new fuel tank and lines. i have ran a wire from the original fuel pump relay to the pump and i have attatched the earth from pump to spare wheel well. the list of new parts goes on, cheers.
Old 22-09-2015, 07:12 PM
martysmartie
It needs rewiring from the battery, as your still using the original supply.
Also the spare wheel well isn't the best ground, as it's most likely rusty.
Martin
Old 23-09-2015, 07:23 AM
wheelwizardrefurbs
i now have it from the battery and there is no rust on the car lol cheers
Old 23-09-2015, 09:21 PM
wheelwizardrefurbs
sorted
ekjim
27-08-2015 05:20 PM
Prickly_buzz
25-08-2015 11:33 AM
kosienutter
31
22-08-2015 09:55 AM
dlwarrior
05-08-2015 10:19 AM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: bosch 044 fuel pump running constant on prime
