Cosworth v6 injector upgrade
Old 28-08-2015, 11:18 AM
Russ Hill
Russ Hill's Avatar
Default Cosworth v6 injector upgrade
Hi I am after some advice for a mate of mine with a twin turbo cosworth v6 mini !!!! Running a emerald ecu and 6 triumph throttle bodies and twin plenum chambers
He has had it rolling roaded but it's running out of fuel flow from the injectors as they are standard cosworth ones . We have seen you can fit Vauxhall vectra v6 ones but we can only find ones where the fuel rail sits on top of the injectors and not on the side as there is not room above because of the inlet manifold.
So if anyone knows what side fed injectors will fit and also how to or what needs modifying on the fuel rail to fit the better injectors then can you please let me know
Many thanks in advance
Old 29-08-2015, 03:13 AM
robrs2
robrs2's Avatar
Side feed injectors, Is it a BOB v6 ?
You can fit Nissan RB25DET or SR20DET injectors. RB25's are in sets of 6.
The standard ones will give you up to about 330bhp, depends on fuel pressure.
Or you can use Subaru yellow injectors. They are said to be 550cc or 440cc depends on the year. but in sets of 4 so you wil need two sets.
Also all the above will need different injector plugs fitting. I got two subaru inlet manifolds complete with wiring to do mine.
Remember to swap the o-ring seal from the ford ones to the others.
Rob
Old 29-08-2015, 08:53 AM
doga-ot
wesskitzo
doga-ot's Avatar
Mine has ford mustang 5.5 ltr yellow injectors
Old 29-08-2015, 02:34 PM
Russ Hill
Russ Hill's Avatar
Thank you for the replies I will pass the information on to my friend who has the car . Any more tips or advice on what needs modifications to make different injectors fit the ford fuel rail are very much welcome
Old 29-08-2015, 03:21 PM
RichieST
RichieST's Avatar
Think we need pics of the car!!
Old 30-08-2015, 07:59 AM
Russ Hill
Russ Hill's Avatar
Old 31-08-2015, 12:27 PM
Russ Hill
Russ Hill's Avatar
Hi are the mustang injectors you have used a direct replacement for the standard ones fitted . It's a bob engine if that helps and do you know the part numbers for them ?
doga-ot (31-08-2015)
Old 31-08-2015, 12:37 PM
costina
Live long and prosper!!
costina's Avatar
Omg thats insane😎
So what power did it make?
Paul
Old 31-08-2015, 03:20 PM
Russ Hill
Russ Hill's Avatar
From what I can remember my mate saying I think it was 300 odd and 340 flb of torque at a limited revs of 4200 by the guy running the rolling road until he can get the higher flow injectors
Old 31-08-2015, 03:35 PM
Russ Hill
Russ Hill's Avatar
Oh by the way the whole car was built from scratch by my mate on a budget in his garage over the space of 5 years and it's still running a type 9 box . As far as we know this is the only bike throttle bodied twin turbo bob engine around
Old 31-08-2015, 03:49 PM
doga-ot
wesskitzo
doga-ot's Avatar
yes theyre a direct replacement!
Old 31-08-2015, 06:44 PM
robrs2
robrs2's Avatar
BoB are side feed, mustang are top feed.
moesin2005
23-01-2022 06:28 PM
jason_nike
18-08-2019 10:53 AM
SmudgerByName
52
28-07-2016 06:14 PM
manuel boeckx
13
03-10-2015 02:29 PM
14-08-2015 07:29 AM
Quick Reply: Cosworth v6 injector upgrade
