cosworth no pulse from injectors?
hi folks does anyone know what would cause no pulse at the injectors on my cossie? ive got fuel up to the rail ive got a good spark ive got all the wiring plugs on the correct way. i do have power at the injectors but will not pulse when cranking its got me baffled! any help on this will be greatley appreciated. thanks
Martin
hi lads yes i have power at injectors but they just wont pulse. i have X2 brown earths which are bolted to my inlet manifold how many more is there mate?
I have put a new crank sensor on and its now pulsing but very weak it juat manages to light the bulb. still wont start. Fuel pump is working and got a spark. Cheers
the phase sensor wiring looks rough as f:@k also would this stop it from starting up and getting a very weak pulse? also when i first crank it over it will pulse bright then immediatley dim to the point where its barely visible.
one more thing, when i use the test light on the X2 injector wires they are both constant live is this normal? ? with (ignition on)
wheelwizardrefurbs (21-08-2015)
Ok its burst into life but only running on cylinders 1 and 3. The other two cylinders are sparking and pulsing but wont fire.
big_Rad
15-09-2017 09:36 AM
