Sierra DOHC Idle Issue
1st post so be gentle !
I have a kit car fitted with a Sierra 2.0 8V DOHC with the stock engine management and injection.
Recently when starting from cold the idle has been going to around 1800rpm before dropping back down - if you then blip the throttle, the idle sticks again before dropping.
This carries on until the engine is warm and the ignition has been swiched off once - it then idles perfectly as it always did.
If you disconnect the ISCV wire when its doing the high rev thing it idles at normal idle 900rpm ish even when cold.
I think the ISCV is working ok but something is telling it to hold the revs high - any ideas what is what ? I have soaked the ISCV in petrol and it appears to move fine but im not sure 100%
I think it may have started doing it after fitting a new alterantor belt but cant be sure exactly when it started.
Car seems to run fine apart from this.
Thanks
Thanks
Adam Graham
06-09-2015 06:04 AM
