track rod end
Old 30-06-2015, 11:29 AM
rammer
rammer's Avatar
Default track rod end
Hi All
Hope someone can answer this one I have a track rod end severely worn and I am in the process of changing it, I released the lock nut 1/4 turn, counted the amount of turns (20) to remove the old track rod end , on placing the new one I counted 20 turns but it is 2 turns short of the lock nut, Is this in the correct position and do I tighten the lock nut to the new one, I will get the tracking done but not for another month when back in UK any advice please
Rammer
Old 30-06-2015, 03:32 PM
focusv8
focusv8's Avatar
Go for a compromise.
1 more turn on the ball joint plus 1 turn out on the locknut.
If the old one was badly worn then the new one won't do any more damage.
If you can use 2 pieces of straight timber and a tape measure you can check/set the tracking yourself
Old 30-06-2015, 04:06 PM
rammer
rammer's Avatar
Thank you for the reply I have now changed both sides n/side was 20 turns and o/side was 25, am I right in thinking that if I adjust them 2.5 turns each it should be central and it should not effect the tracking, can test after as you say
Regards
ossie cossie
57
21-11-2022 10:05 AM
ossie cossie
21-09-2015 05:07 PM
BRAM
08-09-2015 07:11 AM
rsstav
07-09-2015 04:43 AM
rsturbo27
05-09-2015 05:08 PM
Quick Reply: track rod end
