2006 Mk6.5 Fiesta, Center brake light removal?
Hi there, I've recently bought a mk6.5 (facelift model) fiesta. The center rear brake light doesn't work. Does anyone know how to remove said brake light? There 2 holes behind it inside the boot and im not sure what i need to do inside those holes.
Also does anyone know if i need a whole new unit or just a bulb?
Thanks
Thanks
You can see a metal clip in each hole. Push the hooks over the metal frame and the reflector will pop out (use thin, flat screwdriver).
It's possible to change the bulb, no need the change everything.
borboyous
22-08-2015 11:17 AM
track.focus'd
12-08-2015 05:53 PM
